-   General Discussion (http://www.diychatroom.com/f2/)
-   -   Buying a home with a 203(k) program (http://www.diychatroom.com/f2/buying-home-203-k-program-71695/)
DownRiverGuy 05-20-2010 03:58 PM
I am looking into a home that I should be able to get for around 40K.
However at first glance there are already around 20-30K worth of issues that need to be done to make the house how I would like it.
Has anyone on here used a 203(k) type FHA loan when buying a home?
Did the home still have to pass the FHA inspection?
Is it hard to do the documentation required to hire out work and how hard is it to document work that you plan to do yourself?
Thanks!
Chris
mark942 05-23-2010 06:03 AM
Be very specific about your end number!
yes
Yes, 203K type FHA says it all.
No
That can get tricky.
Thanks!
Chris
Might I suggest that you talk to your lender, they will in turn give you a packet that has all the necessary requirements & documentation needed.
Here is a link for reference http://www.hud.gov/offices/hsg/sfh/203k/203kabou.cfm
Again, go to your lender for more specifics!
