Burning Muddy Wood ? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 09:37 PM   #1
Rewards Points: 140
burning muddy wood ?
i got a few 12" logs, that were posts set in dirt. of course they got wet, then muddy, at least on the outside. i want to burn these outside. will they burn ?
they are dry now, mostly.
Fix'n it is online now   Reply With Quote
Old 05-13-2012, 09:44 PM   #2
Rewards Points: 12,808
Only one way to find out, try it.
Old 05-13-2012, 10:11 PM   #3
Rewards Points: 140
oh, you can bet on that . but the thing is, i can get more of these before then. but idk if i should.
Old 05-13-2012, 10:32 PM   #4
You may need some dry kindling and/or smaller pieces of wood to start the fire, but once you have a fire going I doubt you'll have any problems. Any moisture will simply turn to steam in the fire; any earth will just fall to bottom with the ash.
pucks101 is offline   Reply With Quote
Old 05-13-2012, 10:37 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you burning them to dispose of them? That's usually a no-no as far as the air quality people are concerned.
I burn some stuff I shouldn't too though.
Journeyman Plumber
Old 05-13-2012, 10:37 PM   #6
joed's Avatar
Rewards Points: 11,546
If you let them dry out they should burn. It depends on what they are made of and how they might be treated. If they are just plain old cedar posts then they will burn just fine when they dry out. The mud won't be a problem. Knock or scrape as much off as possible.
Old 05-14-2012, 09:32 PM   #7
Rewards Points: 140
yeah, i will throw these in with a bunch of smaller stuff, yard waist. i did burn one that was above ground, and it burned fine.
i burn them, simply, because i can. and to get rid of the yard waist. my new yard is a bit over grown. also, i have never been able to have a "fire pit". now i have one, and i sure as hell am going to use it.
i just wasn't sure if the dirt on the logs would prevent them from burning. i plan to try one this weekend.
the parts of these logs that were above ground. these are cut up. and will go in a wood burning stove that i plan to put in my basement. i will "fire it up" only when i plan to hang down there, in the man cave i am building = bad ass home theater, 119" screen and lots of watts. and a pool table.
Old 05-14-2012, 10:41 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Just make sure the wood isn't treated or it will make you sick when it burns. Also if the wood is black Locust it will burn but it will be hard to get it to burn, I had a stick of that stayed in the stove for two days before it finally burned up.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Fix'n it (05-14-2012)
Old 05-14-2012, 11:09 PM   #9
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
If it is creosoted, it will not only make you sick, it may burn thru the side of the stove.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Old 05-14-2012, 11:20 PM   #10
Rewards Points: 140
i don't think it is treated in any way. at least not any more...
Old 07-07-2012, 04:08 PM   #11
Rewards Points: 140
update :
the first log i burned, took a long time to burn up. i think it was wetter than i thought. the last five, i burned em at the same time, 3rd & 4th of july. and they dried out a lot since the the first log. so they burned a lot better. i did have a TON of kindlin to help em burn.
Old 07-07-2012, 04:31 PM   #12
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Make sure you have some dry wood to get the fire going. Once it's going you can pretty much throw anything in there and it shoud burn. I even throw pop cans in the camp fire, they completely vanish after a while. Should probably be recycling those instead though. LOL
What is an alternatve to brick to be used behind a wood burning stove. Roadking305 Building & Construction 8 07-19-2011 09:06 PM
Been looking at some Wood Burning Stoves SELLC HVAC 17 10-20-2009 10:06 PM
Home made wood burning furnace JustinK HVAC 14 10-05-2009 09:26 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
Installing a Wood Burning Stove / Fireplace ddrowe0217 HVAC 3 11-27-2008 04:48 PM
