Bulkhead Removal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-09-2010, 09:51 PM   #1
bulkhead removal
I am interested in removing the rusted out bulkhead at my home, and filling in the void in the poured cement foundation (I do not use the bulkhead and don't need it ) - Should I fill it with poured cement, or cement blocks ? - What about waterproofing ??
Mike
mrich is offline   Reply With Quote
Old 08-10-2010, 06:50 AM   #2
I would tear out the outside walls, at least to below grade level. Fill in the basement wall opening with block, parge coat and water proof. Then fill in the stairwell with fill dirt(tamp every 6-8") and topsoil.
If there is a drain at the bottom, that will have to be blocked or removed. Check local code.
The Following User Says Thank You to Just Bill For This Useful Post:
mrich (08-12-2010)
Old 08-10-2010, 10:23 AM   #3
I prefer an exit from a basement
When looking at buying houses it was one thing I looked for
So take that into account too
If there is a bedroom down there you may need to leave it
Old 08-12-2010, 02:47 PM   #4
bulkhead
I do wonder about resale complications - The thing is it needs to be replaced, and where I never use it, I'm not sure if I want the expense and aggrivation of replacing
Old 08-13-2010, 12:23 PM   #5
Not so new
12penny's Avatar
Rewards Points: 520
IMHO...you'd be way ahead to replace it.
12penny is offline   Reply With Quote
Old 08-13-2010, 01:18 PM   #6
bulkhead
Why, because of resale ?
Old 08-13-2010, 01:41 PM   #7
Not so new
12penny's Avatar
Rewards Points: 520
I think maybe a couple reasons with resale being one of them.
We dont know if this is a finished basement or not and in most municipalities you have to have a point of egress, be it an egress window or a bulkhead door. Doesnt matter if you plan on having a bedroom down there or not.
They make life much easier when you go to replace your furnace, air handler or other large appliance.
I tried to find a price for a bulkhead door and couldnt come up with anything. However, I would think it'd cost more to block up the foundation wall, waterproof it, bust up the old steps and then backfill it then what it would cost to replace the door.
My 2 cents.
Old 08-13-2010, 01:51 PM   #8
bulkhead
The space is partially finished, and has double hung windows - the problem is its not just doors, it is a two piece unit. The lower unit is rusted stairs, walls, and floor - and the upper is the doors. So the problem is getting it out of there, and there is a large deck built around it
Old 08-13-2010, 01:56 PM   #9
Not so new
12penny's Avatar
Rewards Points: 520
hmmmm...got pictures?
Old 08-13-2010, 01:58 PM   #10
I can get some, stay tuned
Tags
bulkhead , foundation
Bulkhead 295yards Drywall & Plaster 3 01-29-2011 11:27 AM
Basement Bulkhead - replacement ideas dinohome General DIY Discussions 2 03-17-2009 07:15 AM
Adding a roof over a bulkhead? 1parkpointer Building & Construction 1 12-08-2008 10:24 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
