Built Under Oven As A Built In One? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-24-2008, 12:04 PM   #1
built under oven as a built in one?
hi i need advice!
I have acidently bought a built in oven (electric) and i needed a built under one.
Is it safe to fit a built in oven under a work surface ( and under a gas hob as well?)
My electirician / gas man will do it but i wonder if its safe to do so
thanks
helen30 is offline   Reply With Quote
Old 01-26-2008, 10:59 PM   #2
remodeling pro
Look at the installation/instruction manuels. It will be clearly stated if the model is approved for under counter applications .
troubleseeker is offline   Reply With Quote
Old 01-26-2008, 11:13 PM   #3
Rewards Points: 5,336
Instructions that came with the Jennair said it could be mounted either way. In either case, the oven is in a cabinet. What concern would it be if it's installed two feet higher ?
Ron
Old 01-27-2008, 04:15 PM   #4
remodeling pro
Ron
If the unit is designed for either location, it does not matter. Models that are not engineered for under counter or under cooktop locations will have clearance problems between the floor and the bottom of the door or drawer pullout, or between the door trim and the countertop overhang. Often they will physically be too tall to fit under the counter top without reducing the height of the toe kick , which leads to the above problems, and the wiring and control panel circuits located in the top of the case, will not have been engineered to be protected from the heat coming from the bottom of the cooktop.
CAUTION: Even though your oven is approved for this location, check the clearances from the bottom of the cooktop to the bottom of the cabinet to be sure it will fit. This type of setup often requires that you have a modern "thin profile" cooktop, which is only about half the depth of many of the older units.
Costs estimate help please for a newbie Basement vs crawl space Cancer Researcher Building & Construction 21 03-30-2012 07:59 AM
Replacing countertop stove and built in oven becky3501 Carpentry 9 06-27-2008 09:41 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 06:05 PM
Is my oven a dodgy shape? SiBG Appliances 2 09-25-2006 08:15 PM
