Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-11-2012, 02:48 PM   #16
In a little over my head
Building Knock down shed
How about something like this? Take 4x8 sheets of T111 or Masonite siding and put a frame plus a stud on the back, creating a top and bottom plate and one stud (24"OC). Drill holes in the "studs" to accept 1/2" x 4" bolts to connect the panels. You'll need a solution for the corners, maybe just metal connectors or a corner post and lags. After the panels are up, put on a second top plate with deck screws, staggering the joints to tie the panels together. The door could be the same type of panel, on hinges. Dimensions of the finished walls would be in multiples of 4'. Bang together some roof trusses with metal connectors, go 24" OC. Deck roof with plywood and deck screws. Stretch blue tarp over plywood and replace as it deteriorates. Easy to build, easy to knock down, all flat sections to transport. You could do the floor the same way, or just set the walls on a gravel pad and do without a floor. Use PT for the bottom plate.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
mae-ling (04-11-2012)
Help with building a wooden foundation for new shed rygar Building & Construction 9 09-20-2011 12:32 AM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Building a shed under my deck. stevez Building & Construction 9 04-29-2009 10:19 PM
Morning Pilgrims! Greenhorn looking for answers! - Need help building a Shed bazzbozz Building & Construction 3 11-11-2008 09:36 AM
Building rafters for small shed simonb Roofing/Siding 4 07-15-2008 01:32 PM
