Building Codes... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 07:05 PM   #1
RealRobD's Avatar
Building codes...
What's the best place online to find your local building codes?
RealRobD is offline   Reply With Quote
Old 07-29-2013, 07:21 PM   #2
Old School
Willie T's Avatar
Call your Building Department.
Willie T
Old 07-29-2013, 07:22 PM   #3
DIY staff
Rewards Points: 7,174
Usually I go to the building department of the town that has jurisdiction---
Old 07-31-2013, 11:39 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Like already said, you need to contact your local municipality to find what code they use and what version/year they've adopted. You'll also want to ask if there are any sections of the code that they have opted out of. Then you can go on-line to purchase a copy, or sometimes the local library may have it.
Old 07-31-2013, 01:16 PM   #5
Once you've determined which codes apply to your jurisdiction you may be able to find copies on this website. https://bulk.resource.org/codes.gov/
Docman is offline   Reply With Quote
Adding Flooring/Drywall/Insulation in Portable Storage Building Ashley DIY Building & Construction 0 07-12-2012 11:06 PM
Trex and Building Codes Jamie O'Leary Remodeling 6 04-19-2012 09:49 PM
Container homes, what foundations does it need?? shabba1985 Building & Construction 27 03-08-2012 01:48 AM
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 03:09 PM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 08:28 AM
