Building Code Compliance: Remove Laundry Shut Off From Bathroom - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 11:11 AM   #1
Building code compliance: remove laundry shut off from bathroom
Building code compliance: remove laundry shut off from bathroom wall. What does that mean? Currently the Laundry room and bathroom share the one of the same walls. The laundry shutoff box is installed on the correct side (the laundry room). So I don't understand this code?
jclee is offline   Reply With Quote
Old 01-22-2013, 11:31 AM   #2
Rewards Points: 13,750
Think your confused, we have no idea what your location is, no idea on what it is your even trying to do, no pictures.
Old 01-22-2013, 11:35 AM   #3
joed's Avatar
Rewards Points: 12,922
Who is requesting this? Is it a home inspector for someone trying to buy your house? Sounds like something they might request.
Old 01-22-2013, 11:37 AM   #4
City is requesting it.
Old 01-22-2013, 12:26 PM   #5
Rewards Points: 1,298
Did you ask the code guy who cited you? He should be able explain it to you.
danpik is offline   Reply With Quote
Old 01-22-2013, 01:40 PM   #6
DIY staff
Rewards Points: 7,174
Tell us what's going on---you will have to ask the code people---
Could it be that you did not mention the work in the permit?
Or are missing the floor drain ,if your area requires one?
Old 01-22-2013, 03:27 PM   #7
Rewards Points: 3,130
Why?? I know of no such code requirement. I've owned more than a couple of homes with the same setup and no code issue.
Old 01-22-2013, 03:50 PM   #8
DIY staff
The homeowner does not know why----nor do we---only the code enforcer has a clue---so he is the one that must answer the question----
Old 01-22-2013, 04:41 PM   #9
Here are some photos.
The second photo is from the inside of the bathroom. The black pipe you see is the drain for the laundry box
Building code compliance: remove laundry shut off from bathroom-image-3061499463.jpg   Building code compliance: remove laundry shut off from bathroom-image-2659245109.jpg
Old 01-23-2013, 07:23 AM   #10
PoleCat's Avatar
Rewards Points: 1,646
I am not seeing a shut off on the bathroom wall.
PoleCat is offline   Reply With Quote
Old 01-23-2013, 05:17 PM   #11
joed's Avatar
It is in the common wall with the bathroom but on the laundry side of the wall.
Old 01-23-2013, 07:41 PM   #12
The laundry box and bathroom share the same wall.
Old 01-24-2013, 02:40 AM   #13
Rewards Points: 2,238
Are there any inline, shut-offs for the supply lines in the wall that we can't see - from your pics?
Around here - seen the same set-up - no compliance problem.
As stated above -
Take your pictures into the Building Dept. and ask the person who wrote
this up - what's wrong?
rossfingal
rossfingal is offline   Reply With Quote
Tiling basement bathroom - remove sticky tiles? aldgagnon Flooring 10 10-25-2010 09:42 AM
Am I SCREWED? Stairs & building code. Armitage Building & Construction 24 06-26-2008 04:05 PM
Building code violation fetzo Building & Construction 18 03-22-2008 02:42 PM
Building to code? jbmike7 Building & Construction 2 03-02-2008 11:15 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
