Builders Advise Please - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 02:29 PM   #1
Builders advise please
I have a split level home with the garage underneath in which my living room is over top of the garage and my floor has a 1" dip in it only above the garage, what can I fo to repair it?
Alcarte is offline   Reply With Quote
Old 01-29-2011, 03:07 PM   #2
Rewards Points: 5,336
Need a little more information about the house.
Age of building?
Any other evidence of this dip? Such as cracks in the living room wall or ceiling? Cracks in the garage walls? Floor?
Any major renovations done to the house?
Is this an issue that's new? Existing along time?
Are you new to the house?
Ron
Old 01-29-2011, 03:09 PM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Age of building?
Ron
middle of the room?
around the walls?
Big area?
small area?
tcleve4911 is offline   Reply With Quote
Old 01-29-2011, 03:21 PM   #4
The home was built in 1978, it only has some settling cracks under the large beams across the cathedral ceiling, however it was notice with the new carpet was being installed, and it's only about a 12x12 area that has this dip directly center of the 2 car Garage underneath
Old 01-29-2011, 03:22 PM   #5
And yes I just purchased the home about a year ago
Old 01-29-2011, 03:35 PM   #6
Originally Posted by tcleve4911
middle of the room?
around the walls?
Big area?
small area?
About a 12x12 area in the center of the lr dr area directly over the garage, just purchased the home a year ago it was built in 1978
Old 01-29-2011, 03:49 PM   #7
Is there and evidence that there was a support pole in the middle of the garage?
Ron
Old 01-29-2011, 03:59 PM   #8
Looks as if there may have been a post at 1 particular time, but that's about 4 feet from where the the floor starts to sag
Old 01-29-2011, 04:04 PM   #9
I would look at the span you have in the garage and the framing members that are there.
My guess is that someone removed supports and the ceiling joists have dropped as a result.
Ron
Old 01-29-2011, 04:10 PM   #10
Thanks, I was just in the garage area and noticed the there's a sagg in the tapeline running completely across the center of the garage over the area that's sagging above
Need advise: Additional support for existing lally column vluzhko Building & Construction 6 05-17-2012 07:56 AM
Painting on Builder's paint/primer in new condo zfarsh Painting 8 05-24-2010 10:38 PM
looking for 203k certified builders sheryl@lnf General DIY Discussions 1 11-23-2009 07:15 PM
Cool Tools Builders' Show 2009 in Vegas -item help DesertPaso Tools 7 09-24-2009 01:41 AM
Touching Up Builder's Grade Paint - HELP!! candisue7 Painting 8 04-26-2009 03:52 AM
