Build A Large Water Tank/aquarium? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 12:23 AM   #1
build a large water tank/aquarium?
How would I go about building a really large water tank that can hold a person?
Similar to the one in this video:
I have no idea where to start. Should I use glass or plexiglass? Where could I even get a thick sheet of glass like that?
I'm doing this for a photo shoot, so it would only be filled with water for approximately an hour then drained. So it doesn't need to be able to last for a long time.
somethingpunk is offline   Reply With Quote
Old 02-10-2010, 10:43 AM   #2
Rewards Points: 5,336
I would look to rent one if you have no idea on how to start.
Glass would not be the way to go in any case unless you were going to photograph someone hemorrhaging.
Ron
Old 02-10-2010, 10:59 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Ron
Journeyman Plumber
Old 02-15-2010, 09:49 PM   #4
Ron
Well from what I've seen it's very expensive to rent one, as they think you'll be earning money from whatever you're renting it for. I would really like to build one. I guess nobody here knows how to go about doing that?
Old 02-15-2010, 11:26 PM   #5
How big is really big ?
Old 02-15-2010, 11:47 PM   #6
Rewards Points: 1,220
That is probably a $30,000 tank in that video. You could certainly build one, although it would have to have angle iron corner supports. Regardless, your cost is still going to be in the tens of thousands.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 02-16-2010, 02:19 PM   #7
Just looked at the video.
Tank size is what, 6 'wide x 5 feet high?
Sides are 1" -1 1/2" plexiglass?
Materials
4 sheets of 5'x6'x1" plexiglass is $855. a sheet so $3420.
1 sheet of 6'x6' for base is 1500.
Total $4920.
Plus tax and delivery 500.
Total $5420.
For 1 1/2" plexiglass the cost would be $14,259.
Just add the cost of glue and you're done.
+ the knowledge to hold it together
Is this a realistic project?
Ron
Old 02-16-2010, 03:28 PM   #8
That plexi/glass is at least 3 inches thick.
Old 02-16-2010, 03:39 PM   #9
Call it 2.5":
Best price I can find is for a 4x8 sheet at $5600 X 5= $28,000 plus shipping. Add more for special sizing and taxes.
Old 02-16-2010, 03:57 PM   #10
Originally Posted by Tscarborough View Post
Call it 2.5":
Then add the weight of the water. Wherewould you build this that could hold the weight?
Get a 10 gal tank and a Star wars figure.
Who'll know?
Ron
Old 02-22-2010, 10:33 PM   #11
Depending of what you are looking for (depth/ number of glass sides) you may get by with a Plywood aquarium like this one. It only has one glass side but you could probable have it with two glass sides without problems.
I hope you can manage to take the pictures you want!
asfd is offline   Reply With Quote
Old 02-22-2010, 11:33 PM   #12
BJ
An Aquarium window
My house is on Tampa Bay. I added a room onto the back that had 20' of sliding glass doors to keep the view, but I ended up loosing the view from the dining room and Living room.
To keep the view I build a 4 X 6 Aquarium into the wall.
I used glass. You are going to get that green mold buildup on the sides of the tank, especially one with sunlight shinging through it. The magnetic scrubbers work to a point, but it seems like I always had to do at least some work with the razor blade cleaner. That's eventually going to mark up Plexiglass.
I saw one in a house that was a huge half circle of glass, and saltwater. There was even a circular stairway that went to the top. The company that mainteined it literally used SCUBA gear to get into the tank to clean it.
Naturally, these people had the money to afford an aquarium that you can SCUBA dive in.
BJLower is offline   Reply With Quote
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 02:56 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Tankless or tank, but not both gp_wa Electrical 43 10-15-2008 11:08 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
