Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-08-2011, 09:19 AM   #1
Bryant 373LAV error 34
Hello, I started receiving this error in the past couple days. I have removed the flame sensor and cleaned it, same problem existed. I replaced the flame sensor and the system ran for about 30 minutes then shut down with the same error code. I cleaned the green wire connection to ground and checked the connector also. The flame is a crisp blue flame, but will not remain lit longer than 30 minutes and some times just two seconds....
Any ideas would be greatly appreciated!!!!
Bacarter is offline   Reply With Quote
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 30 08-07-2012 10:43 AM
Bryant Warranteed heat exchangers issues TruckTahoe HVAC 0 02-14-2011 03:21 PM
payne heat pump with older bryant fan coil macmichael HVAC 6 11-04-2009 07:23 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Bryant won't shut off reojim HVAC 1 12-12-2008 11:36 PM
