Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-20-2010, 09:00 AM   #1
Post
Bryant 355MAV furnace
I have a 355 MAV high efficiency furnace. It was installed in 1995. When I run the diagnostic test the furnace goes through the test with no errors, including the blower fan going into low and high spped mod. For some reason when the furnace calls for heat everthing looks and sounds good except the furnace stays in low blower spped and does not go into the high speed mode. I get no error codes. I replaced the circuit board and still the same issue. Any help would be great. Is it time to change the furnace?
Beaumont is offline   Reply With Quote
Old 10-20-2010, 09:05 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
If it checks out in the self test, next question is, what type of thermostat do you have. Before you started to mess with it, what other things have you done to it prior before posting here?
Old 10-20-2010, 09:21 AM   #3
It's a Honeywell RTH8500D touch screen. The only thing I did is change the circuit board in the furnace because I was told that was the problem, but after changing it I still have the same problem.
Old 10-20-2010, 09:27 AM   #4
gregzoll's Avatar
The only other question is, is the thermostat properly set up for your furnace. If it is not, the furnace may not ramp properly. Also, there is a time frame before it may ramp under demand.
Old 10-20-2010, 09:50 AM   #5
I will check the thermostat to make sure. I did let it run for 1 hour.
Old 10-20-2010, 10:26 AM   #6
gregzoll's Avatar
If you can not find the manual, honeywell's website has it. Going through the settings on ours, I reloads that it was not set up properly for our furnace, even though I do not remember setting it for a lower efficient type furnace.
There is a setting for single and two stage on these thermostats, in which the furnace needs to have the dipswitches set properly for the furnace to work correctly also.
Old 10-22-2010, 07:51 AM   #7
I checked the termostat and everything is ok. Soemthing is not signaling the blower to go inti high speed whn I have high heat.
Old 10-22-2010, 08:25 AM   #8
gregzoll's Avatar
As mentioned before, two things would cause that; thermostat & circuit board settings. Unless something was changed from the last season, which leads me to believe that it was, due to mention of running it in test mode, it should still run like it did last season.
Old 10-22-2010, 08:27 AM   #9
I had the same problem last season but did not realize it. The reason I noticed it this year is because when I put on my air conditionner in Luly my system frozeup and that is when I realized my furnace blower would not go into high speed.
Tags
355mav, blower, bryant, furnace
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 30 08-07-2012 10:43 AM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 08:11 AM
