Brush On Liquid Membrane - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 03:46 PM   #1
Brush on liquid membrane
I am moving house and the cellar needs to be properly sorted and needs drywall done. Should I use a liquid membrane or rolls....???
AngusFraser is offline   Reply With Quote
Old 08-02-2011, 04:25 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Any waterproofing of basement walls should be done outside not inside.
Where are you?
XXX
Old 08-02-2011, 04:38 PM   #3
DIY staff
Rewards Points: 7,174
Angus,Welcome to the forum----I've move this question to 'General Discussion'
Where are you located?
Concrete or block foundation?
Is there a water problem that you know of,or are you thinking of this waterproofing as a preventative measure?
Old 08-03-2011, 02:55 PM   #4
Where are you?
I am in northampton.. It is a brick built house...
Old 08-03-2011, 05:01 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
All the more reason to do it on the outside. Which of course isn't going to happen now. Anything you do inside in an attempt to waterproof a below grade wall will be mostly wasting your money.
XXX
Keraflor for Kerdi membrane myfirstbathroom Tiling, ceramics, marble 9 04-20-2011 01:21 PM
Torch on roof membrane on deck canada55 Roofing/Siding 36 03-03-2011 02:18 PM
Cutting - in Illinois G.C. Painting 11 11-24-2008 02:04 PM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 05:16 PM
