Broken Window W/ Contact Paper - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 05:44 PM   #1
Broken window w/ contact paper
We moved to a house and have a front window and its a bigger window showing our other half of our front yard and front door, the only thing is that is covered with contact paper that is sort of frosty, so you cant see in or out and no sun can come in.
i pulled a corner of it off and scrubbed with rubbing alcohol to get off the stickiness and I want to do the whole thing. I just dont know what i would put over it in the meantime.
dont have any money right now but will in 2 weeks. is there a temporary thing i can do until 2 weeks and i can buy some clear contact paper.
would packaging tape work?
the crack is like a V in the glass.
any suggestions on how i could remove this but still keep the cold out, but let the sunshine in and be able to look outside?
Thanks!
nicknjacki is offline   Reply With Quote
Old 10-08-2010, 06:39 PM   #2
Rewards Points: 5,336
You might try super glue to stabilize the break.
Ron
Tags
broken window , contact paper , cracked window , window covering
window performance question renbelle Building & Construction 4 10-06-2010 02:25 PM
Bathroom window issues? Mantaray14 Remodeling 11 12-04-2009 07:40 PM
I rejected this new window - was it bad? bmack500 Building & Construction 9 10-13-2009 11:31 AM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 10:00 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
