Broken Off Bolt - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 03:17 PM   #1
Broken off bolt
Hoping someone here can help. Broke a bolt inside part of my elliptical. Tried using a spiral screw extractor with no luck. Any other suggestions would be appreciated. Picturs show location of broken off bolt, size of bolt, and extractor.
Steve
Broken off bolt-image-259093860.jpg   Broken off bolt-image-1492065735.jpg   Broken off bolt-image-3379766042.jpg
gerardswork is offline   Reply With Quote
Old 05-27-2012, 03:52 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by gerardswork View Post
Broke a bolt...
Did you drill a hole into the bolt first?
Cutting to the chase...
Can you buy the part that bolt is attached to? Is it expensive?
Is it a serious PITA to replace?
Old 05-27-2012, 03:57 PM   #3
Framing Contractor
Rewards Points: 120
Make sure the extractor is the proper size. You could also attempt to drill out the remaining threads using a drill that is slightly smaller. It is hard to keep the drill straight though, and it could cause further damage.
sixeightten is offline   Reply With Quote
Old 05-27-2012, 04:53 PM   #4
Thanks for the replies...the part is the main connector to flywheel...no chance of replacing that....the directions said to drill a pilot hole...so i just drilled in a little bit...or should i drill the hole all the way through first?
If that still doesnt work...any other suggestions?
Old 05-27-2012, 04:54 PM   #5
@618... Do you mean basically just try and drill out the bolt...basically disintegrating it?
Old 05-27-2012, 05:07 PM   #6
Framing Contractor
Rewards Points: 120
That was the plan. It is very risky, as you could damage the remaining threads or other parts. I would make another attempt with the extractor first if I were you. Follow the package directions exactly and make sure you are using the correct size.
Old 05-27-2012, 05:09 PM   #7
Rewards Points: 40
Some bolts connecting to flywheels are left hand thread. This is so they tighten rather than loosen, depending on the rotation direction.
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
Tom Struble (05-27-2012)
Old 05-27-2012, 06:15 PM   #8
Rewards Points: 3,748
Thats to risky,try extracting at all costs,here's a link that might help.
http://www.wikihow.com/Use-a-Screw-Extractor
Canarywood1 is offline   Reply With Quote
Old 05-27-2012, 07:42 PM   #9
Rewards Points: 1,062
yup, you have to pre drill first for the extractor to "bite in". If the drill "walks", try a nail punch in the center of the broken bolt....
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 05-27-2012, 08:03 PM   #10
I think you meant a 'center punch' !
The Following User Says Thank You to Wildie For This Useful Post:
noquacks (05-28-2012)
Old 05-28-2012, 08:13 AM   #11
Rewards Points: 236
the pic is crappy. but it looks like you didn't drill the hole big enough.
Fix'n it is offline   Reply With Quote
Old 05-28-2012, 10:53 AM   #12
In a little over my head
Rewards Points: 706
The hole in the bolt MUST go all the way thru. That helps relaease the tension on the bolt and allows it to shrink a little. The extractor should be as large as possible, as should the hole. Warning: If the extractor breaks off in the hole, your day just got MUCH worse. Try the extractor gently. If it doesn't work, quit. Drill the hole to the correct TAP size, and use a tap to break out the remaining metal. You may still end up installing an insert (heli-coil or time-sert). If that's the case, try taking the part to a good auto mechanic. They usually get good at this stuff. Figure paying for about an hour's work.
ratherbefishing is offline   Reply With Quote
Old 05-28-2012, 11:12 AM   #13
right- thanks wilde....
Old 05-28-2012, 01:05 PM   #14
Maybe im not pushing hard enough....but drilling the hole is taking forever...are there any tips or strategies when trying to drill the hole...ive been at it for 15 minutes and dont feel like im making progress.
Old 05-28-2012, 01:29 PM   #15
kwikfishron's Avatar
Rewards Points: 832
What diameter are you trying drill?
Are you using a "new" bit made for drilling steel?
The drill is set on forward, right?
kwikfishron is offline   Reply With Quote
Broken bolt on boiler iamsaws Plumbing 2 01-27-2012 08:01 PM
Need Hex Bolt for Older Velux Skylight xquercus Roofing/Siding 0 05-26-2010 01:19 PM
Mounted tv isn't straight :-( scottycam Building & Construction 13 05-01-2010 12:20 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
My dead bolt is broken kimigriffith General DIY Discussions 3 06-09-2008 12:02 AM
