Broken Metal Swing Question With Pics. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 02:22 PM   #1
Rewards Points: 262
Broken metal swing question with pics.
I have this swing that I want to make a quick repair on. As you can see in the pictures the metal rod rusted through. I want to replace this rod with a length of chain. I have a picture in my mind of the hardware piece I need to attach the chain to the bolt in the arm of the swing but can't find it or a name for it. That is what I need help with. A chain will attach easily to the spring above, no problem there.
Broken metal swing question with pics.-p1000607.jpg   Broken metal swing question with pics.-p1000608.jpg   Broken metal swing question with pics.-p1000609.jpg   Broken metal swing question with pics.-p1000610.jpg
Jim F is offline   Reply With Quote
Old 08-29-2012, 02:52 PM   #2
Rewards Points: 12,858
Most likly what your looking for is an eye bolt.
Going to have to mount it from the top not the side or it's going to bend and rip out the metal on the arm rest.
Use a washer on it and an elastic stop nut. Try to find a welded eye not one just bent over.
Jim F (08-31-2012)
Old 08-31-2012, 11:51 PM   #3
Rewards Points: 262
Yeah I think your right Joe. The eyebolt is my best option. Something like a towing shackle was what I was thinking about before but that would just be too expensive.
Old 09-01-2012, 08:28 AM   #4
Household Handyman
Rewards Points: 1,408
A spring such as the one you have it readily available from sources such as "Fastenal, "Grainger", and "McMaster-Carr". Good strength and more flexibility than an eye bolt.
Old 09-01-2012, 10:44 AM   #5
Bombastic Idiot
notmrjohn's Avatar
jim, I'm not sure I understand all I know about this. You and joe plan on drilling a vertical hole thru the arm and attaching chain to eye bolt ? How will you attach chain to eye? S hook? I like your shackle idea better, you'll need a lomger bolt but if you can get a wide enough shackle to fit over arm it will pull on both ends of bolt. I've seen a whole lot of those where the bolt hole is rusted and pulled all out of shape on the weight side.Sometimes bolt rotates in hole wearing away at hole, homemade metal tube bushings help there., You could use a chain with links big enough for bolt to pass thru, washers against chain and nylon insert stop nut, or proper length bushing, so it doesn't have to be snugged against chain. Or S hook on end of chain, bend in so won't slip off chain, blt thru other end of S bent to stay on bolt. And if you turn those bolts around so nut is on outside, less chance of sumbudy snagging themself on that bolt end.
Had to edit, had another idea. At Hardware store you'll find mending plates, (not the thin ones for wood construction, thicker for machinery repairs) among them are short lengths of flat metal stock with a hole at each end, depending on length more holes. Find one of width near that of the rusted rod, holes big enuff for your bolt and long enuff to have hole at one end bolted to sound part of rod and swing bolt thru hole at bottom end. Two holes and bolts on the rod end would keep plate from swinging at that end. I'd best go B4 I have more brilliant ideas. You got any rope you're not usin layin around? You could.....see what I mean?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-03-2012, 02:52 PM   #6
Rewards Points: 262
Done. Here are some pics. Thanks to all for help. Now, the seat is ripped out. Truthfully this swing is ready for the landfill but it is still built better than anything they sell nowadays so I am seriously considering fixing the seat next. My daughter has autism and is very hard on furniture so I will keep this swing in service as long as I can.
Broken metal swing question with pics.-p1000611.jpg   Broken metal swing question with pics.-p1000612.jpg   Broken metal swing question with pics.-p1000613.jpg
Metal Building Foundation Pics CaptainD51 Building & Construction 8 12-23-2011 11:57 AM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 11:12 AM
5V crimp metal roof underlayment question ugabulldog Roofing/Siding 1 06-21-2008 01:22 AM
a question about a broken shingle beej Roofing/Siding 4 01-06-2008 11:18 PM
Welding / faceplate modification question (see pics!) joeyboy General DIY Discussions 17 09-23-2007 06:54 PM
