Broken Deadbolt - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-15-2007, 05:11 PM   #16
http://www.cornerhardware.com/howto/ht021.html
click on "play" and then "install lock".
This will show how the lock is installed.
Reverse the process to remove the lock from the door.
Once you remove the two door plates then you should be able to manually retract the deadbolt back into the door.
redline is offline   Reply With Quote
Old 12-16-2007, 09:37 PM   #17
remodeling pro
Why do you have to drill it out. The cylinder has to be removable, it certainly was not machined on the door . If there are screws visible on the cylinder, remove them and the two halves of the deadbolt will separate, allowing you to flip open the latch bolt with a screwdriver. If it has no visible screws, it is held in place by the interior trim ring screwing onto the body of the exterior half. Grip the ring with some channel lock type pliers and turn it counter clockwise . If it does not move readily, you may have to hold a sharp chisel against the ring and tap it so that it bites into the ring and rotates it. Sounds like you should be prepared to replace the deadbolt, as either of these will leave some scars on the trim ring.
troubleseeker is offline   Reply With Quote
Old 12-16-2007, 10:05 PM   #18
remodeling pro
Originally Posted by gregzoll View Post
There should be plugs covering the screws on the interior side of the door. Once the door is removed by pulling the hinge pins, you should be able to take off the Dead Bolt and install a new one.
Unhinging the door has no effect on being able to separate the two halves of the cylinder. I think there is a misconception that he will be able to remove the "bolt" from the edge of the door, and somehow this will allow the cylinders to separate, but it is not so. The inner and outer cylinders are secured to each other, either by screws or by the two halves threading together.
Old 12-16-2007, 10:36 PM   #19
Rewards Points: 6,652
Unhinging it will help it pulling the door off to place on saw horses to be able to get the old one off, especially if the bolt is currently extended.
Old 12-17-2007, 01:04 AM   #20
If you look at the key, you - or someone at the local HD or hardware store - should be able to tell if it's a Kwikset, Segal, Schlage, Weisner, Titan, etc. Each key has a distinct shape to its head and Kwikset and Segal are by far the most common ones used in residences over the years. Schlage is more common to commercial.
End Grain is offline   Reply With Quote
Old 12-17-2007, 10:38 AM   #21
There's got to be a way to remove the cylinder from the inside. Try unthreading the trim. I don't believe taking the door off the hinges will get you anywhere, except make you cold.
NateHanson is offline   Reply With Quote
Old 12-17-2007, 09:51 PM   #22
Eibwen
I.D.'ing the the brand would definitely help as there are some deadbolts where access to the end of the bolt is a must to remove it from the door.
And since no brand names have been visible this is also one of the last places there may be a brand name posted.
Key head shape could help with ID although apparently there are no names or numbers on the key to point towards a particular mfg.
A pic would definitely help. Even a cell phone camera.
Sammy is offline   Reply With Quote
Old 12-18-2007, 12:00 AM   #23
Rewards Points: 5,336
Locks have access points on the interior. Just unscrew the inner cylinder, pull it out and access the latch mechanism.
Two pages of posts, what are you doing, launching the space shuttle?
Ron
Old 12-18-2007, 09:04 PM   #24
Eibwen
Not all locks will have bolts exposed to the interior as the more common brands due.
I think the original poster either called a locksmith or never checked back.
Launching the space shuttle?
Now thats a whole new thread!
We're gonna need a really big sling shot, some insta foam for the stuff that always falls off the wings wings and we better call NASA!
broken lug studs LanterDan Automotive Repairs 19 02-01-2009 09:13 PM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 11:45 PM
Broken Drill Bit Freelancer General DIY Discussions 15 03-29-2007 05:01 PM
Broken Brake Shoe powrus Automotive Repairs 11 01-16-2007 06:40 PM
Deadbolt suddenly won't retract Squeeealer Carpentry 1 07-14-2005 09:20 PM
