#1 |
broken deadbolt
my deadbolt is broken and locked, does anyone have tips on how to drill it out without calling locksmith..thanks
#2 |
Eibwen
broken deadbolt
Is it keyed on both sides or does it have a thumbturn on the inside?
Any brand names on the lock or the key? Whats broken on it? |
#3 |
broken deadbolt
keyed on both sides, key just turns, doesnt catch....brand unknown...are there other options besides drilling ? i know i will have to replace
#4 |
Eibwen
broken deadbolt
If the key spins completely around without stopping it would point to a broken tailpiece that connects the cylinder to the bolt.
Have you tried the key from both sides of the door? Any names or number on the key that operates it? |
#5 |
broken deadbolt
have tried both sides, key doesnt turn 360 degrees but about 320 degrees and stops, no numbers or brand, old lock original i assume
#6 |
Eibwen
broken deadbolt
Could be the bolt has died in the extended/deadlock postion which is somewhat rare but does happen.
Are there any visible screws on the inside? Can you post a pic? |
#7 |
broken deadbolt
there are no screws and we don't have a working digital camera so no pics
#8 |
Eibwen
broken deadbolt
Any idea how old the lock is?
#9 |
broken deadbolt
probably at least 15-20 years old
#10 |
broken deadbolt
Take the hinge pins out.
Remove the door to further access the deadbolt. |
#11 |
Eibwen
broken deadbolt
Hmm thats a toughy without knowing a brand name or having a pic to id.
Could be one of several brands all with different mounting methods. |
#12 |
Eibwen
broken deadbolt
Good point Reline..
That would at least expose the bolt edge where most mfgs put thier name. |
#13 |
broken deadbolt |
#14 |
Woodworker and Contractor
broken deadbolt
get a "steppped drill bit" and drill right though it. Then open the bolt with a screw driver
#15 |
Average Joe/ex-Navy IC3
broken deadbolt
There should be plugs covering the screws on the interior side of the door. Once the door is removed by pulling the hinge pins, you should be able to take off the Dead Bolt and install a new one.
| Display Modes | |
| broken lug studs | LanterDan | Automotive Repairs | 19 | 02-01-2009 09:13 PM |
| Tool to deepen deadbolt hole? | darsunt | Carpentry | 5 | 07-18-2007 11:45 PM |
| Broken Drill Bit | Freelancer | General Discussion | 15 | 03-29-2007 05:01 PM |
| Broken Brake Shoe | powrus | Automotive Repairs | 11 | 01-16-2007 06:40 PM |
| Deadbolt suddenly won't retract | Squeeealer | Carpentry | 1 | 07-14-2005 09:20 PM |
