Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-24-2011, 09:04 PM   #16
Broken Ceramic Toilet Paper Holder - Built in
Here is an exact picture of what i'm working with; my "clean wall hole". Note there is a little bit of plaster/whatever that chipped out all the way to the metal mesh back. my goal was to fill this in all the way so there isnt breakage or pieces moving around in years to come.
RE: It being the wrong one" - This was actually the ONLY ceramic toilet paper holder I found after searching about 5-6 places here in Atlanta. I found this one at a specialty floor/tile place, and it was the ONLY one they had.
Bud, I will try to research your suggestion in regards to modified thinset.
If there are any additional suggestions, I'm open. and always, Thanks a ton for your help!
Broken Ceramic Toilet Paper Holder - Built in-cleanhole01.jpg   Broken Ceramic Toilet Paper Holder - Built in-cleanhole02.jpg
doublerc is offline   Reply With Quote
Old 07-25-2011, 10:39 PM   #17
Originally Posted by Bud Cline View Post
YOU MUST USE MODIFIED THINSET MORTAR for this installation.
Will this brand/type of mortar be the correct "modified thinset" for this application?:
http://www.lowes.com/pd_3433-1295-00...tar&facetInfo=
Mix it fairly dry.
How many parts, water to mortar do you recommend to "mix it fairly dry" vs the average mix you would do?
Old 07-26-2011, 08:10 AM   #18
Tileguy
Bud Cline's Avatar
That thinset will be fine.
I have no idea. I would just start off mixing until it gets pasty. Thinset will run and sag fairly easily so you'll just have to play around with it a little. Sorry I don't have a better answer for you on that score. I always mix thinset by sight and by feel.
Tags
bathroom, tile, toilet paper holder
Bread, Milk, and Toilet paper - Snow Madness Leah Frances Off Topic 40 02-13-2010 07:22 AM
Towel rod and toilet paper holder dnbreaks Remodeling 4 01-30-2010 04:24 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet paper holder/towel ring Danieheiz Remodeling 4 03-05-2008 11:25 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
