Brick Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-07-2007, 01:02 AM   #1
brick wall
i want to make one of my interior walls all brick. the wall is 20' wide and about 20' high. it is on the first floor and the house sits on a crawl space. do ii need to do anything to reinforce the floor to support the weight of the brick and how do i secure the brick to the wall so it doesnt fall over? If you know of any sites that demonstrate this please forward. thanks, duane
dephipps is offline   Reply With Quote
Old 12-07-2007, 06:22 AM   #2
Rewards Points: 16
You will need to add major floor support to hole this, probably some footings and a metal beam. The brick will get held to the wall with metal straps that you screw into the wall and get mortared in with the brick.
ponch37300 is offline   Reply With Quote
Old 12-07-2007, 09:01 AM   #3
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
use brick faces that are only about 1/2" thick other wise the weight is way too much
Kingfisher is offline   Reply With Quote
Old 12-07-2007, 11:09 AM   #4
Rewards Points: 1,232
An adheered veneer, either fake brick or real brick sawn thin are your only realistic alternatives. Strip off the sheetrock, apply hardi-backer, thinset the brick, tuckpoint, and Voila! brick wall.
Cultured Stone, Eldorado Stone, and Robinson brick all produce these products.
Tscarborough is offline   Reply With Quote
Old 12-09-2007, 03:50 PM   #5
remodeling pro
You will definately want to use the face brick products here, or face some major structural beefing up to support that much brick over a crawl space.
Some of the man made products are pretty convincing, but you can buy real brick that has been sawn into 1/2" thick pieces , thus eliminating any possibility of a fake look. Install a tile backer board of your choosing, adhere with thinset, and morter the joints.
Add extension rings , available at big boxes or electrical supply, to electrical boxes to make up for the additional wall thickness.
troubleseeker is offline   Reply With Quote
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Siding and Brick veeneer wall? sandyman720 Building & Construction 9 08-13-2007 05:02 PM
Brick wall needs repainting BilHam Painting 3 07-19-2007 10:17 PM
Doorway though brick wall. archangel689 Building & Construction 3 04-20-2007 10:23 AM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 10:09 AM
