Brick separating from the block
First of all call a professional for a visual inspection and assesment. 6 yrs old may still be under your new home warranty.
I worked on a hotel where the brick ties that held the brick facia up rusted away and one wall did collapse and crush 6+ cars. For the other walls we drilled through the bricks to the block wall and anchored them together with some custom decrotive washers that were 4" in diameter and made a decrotive pattern on the walls while doing this.
You will not be able to suck the brick wall back in, all you can do is anchor it to stop it from getting worse, or tear it down and redo it. Again, you will need a professional on site assesment for this.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
