Brick Patio Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-28-2009, 10:01 AM   #1
Brick Patio Issue
Our patio was built with our house about 5 years ago and it seems like the sand is erroding from between the cracks. What would we need to do to fill those gaps and what tools/kind of sand to use?
Jfreres is offline   Reply With Quote
Old 07-29-2009, 10:39 AM   #2
Registered User
Termite's Avatar
I moved your post from the how-to guides subforum as it is a question and not a how-to guide.
Is your brick patio dry-laid or are the joints mortared? If it is dry-laid just take a push broom and sweep fine dry sand all over the patio. Work it back and forth so it fills the gaps between the pavers or bricks. That's how it is done when pavers are laid, and it is a maintenance thing that you may have to do from time to time.
drainage issue on patio supaflyz Landscaping & Lawn Care 1 08-18-2009 02:44 PM
Brick haze on brick over slab patio joeconroy Building & Construction 17 09-08-2008 01:44 PM
Brick up against sliding patio door with J Channel? sandyman720 Building & Construction 2 09-28-2007 08:47 AM
Steps on an umortated brick patio schott_robert Building & Construction 2 12-04-2006 08:15 AM
