Brick Molding To Seal Or Not? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-30-2013, 11:51 PM   #1
Rewards Points: 16
Brick molding to seal or not?
I have an older house approx. 80yr with the old glass stucco.
There is a brick molding on the bottom and there is a small gap between the stucco/lath and also where the building paper overhangs onto the concrete.
See picture attached, not to scale or anything like that.
I have perry winkle trying to grow up behind the brick molding and I am wondering if I should seal in behind the brick molding against the concrete?
If I seal it should I use caulking or spray foam?
For the most part all the wood is OK behind the brick molding, some small amounts of water damage but nothing severe enough to have to fix.
ekih is offline   Reply With Quote
Old 08-31-2013, 04:47 AM   #2
Rewards Points: 13,260
Should be drip cap there not Brick moulding.
http://www.bing.com/images/search?q=...lectedIndex=46
Would be interesting to see a real picture of what you consider small amounts of damage.
Old 08-31-2013, 11:50 AM   #3
Rewards Points: 16
mostly staining, remember that this is an old house with old shiplap.
The brick molding is acting as a drip cap, has a beveled angle to direct the water away.
The question is to seal or not the bottom of the drip cap?
Trying to remove base molding h22lude Flooring 3 05-29-2013 01:59 PM
Repaired brick wall meets vinyl siding leak diynonstop Building & Construction 5 04-18-2013 03:43 PM
Can you seal brick on fireplace? mrs1885 Remodeling 3 03-29-2011 11:52 AM
Vinyl windows and brick molding a7ecorsair Building & Construction 4 08-10-2010 09:54 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
