Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-29-2012, 11:34 PM   #1
brick fireplace conversion
I want to convert my brick place into a fireplace for outdoor use. The fireplace is conventional brick and is located at the back of the house. If I brick in the front and dry wall it, I would then open the back (which faces the backyard) for outdoor use. I would then build a deck off the back of the house and enjoy my new outdoor fireplace. Does this make sense and could it be done without jeopardizing the construction of the fireplace?
frankpoto is offline   Reply With Quote
Old 01-30-2012, 07:17 AM   #2
Super Moderator
In a nutshell--NO.
A fire box is carefully shaped to create a proper draw and draft----back curved--damper to the front of the fire box---Simply closing off the opening and making a new opening in the back will not draw right.
The fire box would need to be reshaped,too.
sdsester (01-30-2012)
Old 01-30-2012, 09:31 AM   #3
sdsester's Avatar
You need to consult an architect/landscape architect, fireplace or chimney expert, or a mason---or all three. What you have in mind is extremely dangerous, will not pass code, and will invalidate your fire insurance policy instantly. As mentioned, you (hopefully) have a firebox designed to draft fire properly. It will not work backwards.
You are probably better off designing and building a new fire feature element, with its own chimney, from scratch in your outdoor living area?
sdsester is offline   Reply With Quote
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 07:46 PM
Can you seal brick on fireplace? mrs1885 Remodeling 3 03-29-2011 11:52 AM
Drywall a Brick Fireplace schw1927 General Discussion 1 01-26-2011 04:12 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
Brick Fireplace Paint ... g8master Building & Construction 3 12-20-2009 01:31 PM
