Brass Window Hardware? Cleaning/painting Advice Please - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-17-2010, 02:25 AM   #1
Brass window hardware? Cleaning/painting advice please
Hi,
I have old steel KM windows which I'm renovating. A few questions I was hoping the pros could answer about the window hardware. So far I've tried paint striper, metal magic, a mix of salt, flour and vinegar and plenty of steel wool, but can't get them clean.
Is this solid brass? A magnet does not stick
It has dark brown, dark red and green areas of discolouration. Is this all tarnish?
Is there a good way to clean them?
Brass window hardware? Cleaning/painting advice please-photo-1.jpg   Brass window hardware? Cleaning/painting advice please-photo.jpg
JakeS is offline   Reply With Quote
Old 06-17-2010, 07:00 AM   #2
DIY staff
Rewards Points: 7,174
Suggestion--Send them off to a plater--the cost may not be to bad.
Other than that--buffing wheel and buffing compound.
May be nickle silver(white brass/german silver)
Old 06-18-2010, 03:36 AM   #3
Thanks Mike. Do you mean get them plated, or that a plater might be able to clean them?
Old 06-18-2010, 06:36 AM   #4
Household Handyman
Rewards Points: 1,408
What few of these I have seen, I agree with Mike as far as having them re-plated. They probably are of a base metal with a decorative plating on them and the plating has worn off over time. You might try using one of the many compounds out there for polishing plated materials ( I prefer Wenol) on one to see if it will help. Advice here: Having sent chrome parts from old cars to platers, take pictures of any parts you send, DO get a receipt from the plater as to the parts received and pricing with a % variable. If possible, etch an I.D. number/name on the parts so you know you are getting your parts back. Experience has taught me well on platers. David
Old 06-18-2010, 06:48 AM   #5
DIY staff
Thurman--Sound like you might have had a part or two lost in the acid bath
If you don't know a plater--check out your nearest chopper shop or hot rod shop. They might be able to recommend a service that will do small orders.
Like Thurman said--those were usually a base metal with a nickle plate--
They don't polish well--the plating will wear off.
Replace a window with Bay Window? Eusibius2 General DIY Discussions 4 10-09-2009 11:10 AM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Need a little advice replacing basement window Bcoleman6 Building & Construction 1 06-08-2008 06:49 AM
Any advice on a good brand of air conditioner (window model) ? nubee Appliances 2 06-12-2007 03:24 PM
