Box To Cover Sprinkler Controls.. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-09-2014, 07:54 PM   #1
Rewards Points: 12
box to cover sprinkler controls..
I wanted to build a box to cover the controls for my sprinkler system. I have some pressure treated 2x4s I was going to use. I was wondering what the best was to anchor them to the ground is though. Any suggestions...?
hoffy85 is offline   Reply With Quote
Old 02-09-2014, 08:37 PM   #2
Rewards Points: 28
Why not use the plastic box that is designed for use with those lids?
Dan
djlandkpl is offline   Reply With Quote
Old 02-09-2014, 08:50 PM   #3
Rewards Points: 12
I just thought it would look nicer to have a covered wooden box that opens with hinges. It would also protect the controls and whatnot for the sprinklers. I'm just trying to figure the best way to anchor the box to the ground......
Old 02-09-2014, 09:02 PM   #4
Rewards Points: 28
You could drive 4 stakes into the ground at the four corners. Then screw the box to the stakes.
Dan
Old 02-09-2014, 10:24 PM   #5
Rewards Points: 12
That's kind of what I was thinking but I wasn't completely sure if I should do stakes or if cement would be the better way to go or what.....
Old 02-10-2014, 05:35 AM   #6
Rewards Points: 28
I would not use cement. It will be a pain if you ever have to pull the box to work on the valves or pipes.
Dan
Old 02-10-2014, 10:50 AM   #7
Rewards Points: 12
ok I guess i'll go with the stakes into the ground then. Thanks..!
Old 02-10-2014, 11:03 AM   #8
seansy59's Avatar
Rewards Points: 258
IF YOU USE STAKES BE SURE NOT TO HIT A SPRINKLER PIPE OR CONTROL CABLE!!!!!!!!!
seansy59 is offline   Reply With Quote
Old 02-10-2014, 11:09 AM   #9
Rewards Points: 12
Good point i'll watch out for it!
any violation in painting electrical panel cover? bklynsoulja Electrical 17 12-28-2013 01:09 PM
Patio cover for L shaped house. Godspede619 Building & Construction 0 08-17-2013 06:45 PM
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 10:22 PM
Cover modification for older Murray service panel JeffT Electrical 2 05-29-2012 10:43 PM
Cover for artesian well? bw77 Plumbing 6 11-28-2011 06:06 AM
