Bottom Ext. Door Panel Replacement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-18-2015, 09:21 AM   #1
Rewards Points: 8
bottom ext. door panel replacement
Due to the heavy snows our stationary slider bottom door panel(7 1/2 " wide)is almost totally rotted through,how can I repalce the whole bottom panel--to expensive to replace door
pflan62 is offline   Reply With Quote
Old 08-18-2015, 09:44 AM   #2
Rewards Points: 5,336
Post a photo so we know what the door looks like.
Usually the panels are locked in place by the stiles and rails surrounding it.
To get one out you would need to remove the interior lip holding it in place.
Do you own a router?
Are you good with hand tools?
Ron
B. Franklin 1759
Old 08-18-2015, 10:00 AM   #3
Rewards Points: 8
bottom ext door panel replacement
I have just about every tool,usually good w/repairs and whatever,not sure how to post picture
Old 08-18-2015, 10:20 AM   #4
Go to the, "How To Guides" in the forum home page.
Ron
B. Franklin 1759
Old 08-18-2015, 03:36 PM   #5
Rewards Points: 8
Old 08-18-2015, 04:44 PM   #6
This is the bottom rail, not just a panel. The rot isn't going to be isolated to just the rail. The side stiles will probably also be involved.
If it's just the rail, you will need a shaper and the particular cutter the manufacturer used to cut the profile.
Do you have a shaper? If not, try a local cabinet maker. A cutter for this will run over $100.00.
Ron
B. Franklin 1759
Old 08-19-2015, 05:26 AM   #7
Rewards Points: 6,034
Those almost certainly take specialty bits for cutting rails and stiles these are not cheap. probably better to just buy a door.
Entering your general location can help with answering a lot of times
Old 08-19-2015, 06:25 PM   #8
Rewards Points: 8
bottom ext.door panel replacement
the same type of rail and stile in a cabinet door,if the sides are rotted a new door would probably work better but matching it is another problem. I do have a router table and those bits for cabinet doors which I have made several times
Old 08-20-2015, 06:16 AM   #9
Really don't think they are the same due to the thickness of the door.
Old 08-20-2015, 10:52 AM   #10
A new door would be ideal, but.....
If you have the tools and some experience why not just duplicate the entire door using the old glass.?
ron45 is offline   Reply With Quote
Window Sill Rot, New Construction Replacement? mpg9999 Windows and Doors 8 11-18-2012 07:08 AM
Replacement Windows mdeange Windows and Doors 2 08-16-2012 07:28 AM
Bottom Plate for Stud Wall svaic00 Building & Construction 3 07-10-2012 02:07 PM
2 yr. pool liner has wrinkle on bottom HELP Tric Introductions 0 09-10-2010 12:13 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
