Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-02-2010, 06:12 PM   #1
boring hole in a wood pole
I need to bore a hole and then use the wood as a plug, how do i do that? The wooden pole diamter is about one inch. i just need a shallow hole hole any suggestions would be very helpful thanks
rorionstar is offline   Reply With Quote
Old 04-02-2010, 08:00 PM   #2
Super Moderator
There are hole saws available --but I have never seen one small enough to bore into a 1 inch dowel.
Your best bet is to buy a wood plug (they are sold buy the bag in any big box store)
then drill a hole using a regular bit. Glue in the store bought plug--sand--done
--Mike--
Note---If you must match the wood in your 'post' you can make your own plugs --using a plug cutting bit--Look for the plug cutter in the same section of the store that sells the plugs.
Old 04-02-2010, 10:03 PM   #3
You need to supply a detailed scenario. If the reader can't understand what you're trying to do, you won't get any constructive guidance.
Ron
Old 04-03-2010, 11:16 PM   #4
remodeling pro
Afraid I don't have a clue as to what you are wanting to do here. Can you reword this? Sorry.
troubleseeker is offline   Reply With Quote
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 10:14 AM
Pulled up carpet to put in wood flooring and found 2' plumbing hole in slab. Nightsky Plumbing 1 07-04-2009 08:44 AM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
Wet Rot Fix Koshi9 Carpentry 14 09-02-2008 12:12 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
