Bondo On A Garage Door? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 10:40 AM   #1
Rewards Points: 262
Bondo on a garage door?
Kid that lived here before thought it was a good idea to shoot BB's at the garage so there are several tiny dents. Think I could use automotive bondo to fill them and then repaint it? Nothing functionally wrong with the door so I'd like to try to clean it up rather than replace. Other ideas?
moneymgmt is offline   Reply With Quote
Old 11-13-2011, 11:00 AM   #2
Household Handyman
Rewards Points: 1,408
For either a metal or wooden door, if it's only small places such as B-B marks, I would think some Bondo would work fine. The only problem I could think of would be the slight "flexibility" of the door as it travels. Try it, and if the Bondo doesn't want to stay put because of the door travel, then maybe paint flowers or such over the mark.
Old 11-13-2011, 01:27 PM   #3
Too Short? Cut it Again!
Don't forget to prime the bondo before you paint it! Should probably wet sand with a fine grit too or the patches could end up looking worse than the bb dings.
Personally I would dig the bbs out and use a wood filler if it is a wood door.
Old 11-13-2011, 02:06 PM   #4
Rewards Points: 262
Thanks for the responses. Not a wood door, it is metal. Unfortunately there are probably 100 little bb dings. I'm going to prime and paint it anyway, just thinking I would attempt to clean up the dings a bit before doing so.
Old 11-13-2011, 02:09 PM   #5
Sounds like a plan and good luck. Kid sounds like loads of fun when he grows up and moves on to bigger weapons. Hopefully he will still only be shooting at garage doors.
Old 11-14-2011, 02:11 PM   #6
Rewards Points: 33
I replaced the old, drafty, wood entry door at my house with a steel door with a leaded glass window. I normally wouldn't have bothered with the extra cost of the leaded glass, but it was deeply discounted due to having dings & scrapes from when it was a display model. ($400 door for less than $100) I went to the auto parts store, bought a small can of body filler/bondo, sanded & cleaned the damaged areas, filled the dings & scrapes, then sanded, primed & painted the door. It came out nice, looked like it was never damaged & has held up fine for the last 10 or 11 years.
Bob Deb is offline   Reply With Quote
Door recommendations from basement to garage Tyrus3 Building & Construction 7 07-20-2012 08:12 AM
How to find a garage door dealer meburdick Building & Construction 5 06-28-2011 08:29 PM
Garage Door Assistance dukes32 General DIY Discussions 2 06-15-2011 12:11 PM
Garage Door Install Opinions detailedEye Building & Construction 4 03-31-2010 10:15 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 08:53 PM
