Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-19-2011, 10:20 PM   #16
Tileguy
Bud Cline's Avatar
Bonding formica to old formica
You always apply the edges first. Then router them at 90 degrees flush with the top of the substrate. THEN install the top. Pouter that overage with a 5 degree router bit. Use bearing bits and you can't go wrong and you can't mis-cut anything.
Old 11-24-2011, 09:45 PM   #17
Got it. Thnx.
MajorMedicalBoy is offline   Reply With Quote
Wire size for grounding to water meter? WillK Electrical 18 06-15-2011 11:26 PM
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 04:06 PM
Intersystem Bonding Bar zpm Electrical 0 03-08-2011 02:21 PM
can I apply formica over formica? DIYWayne General Discussion 7 12-28-2008 04:19 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
