Bonding Formica To Old Formica - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 06:09 PM   #1
Bonding formica to old formica
Does anyone here know if it is possible to bond Formica to formica. I do not want to rebuild the top for a table and would prefer to just go right over the old. I have contact cement and also some polyurethane glue laying around.
MajorMedicalBoy is offline   Reply With Quote
Old 11-14-2011, 07:02 PM   #2
DIY staff
Rewards Points: 7,174
If there is a way I would like to know it,too.
I was always taught that that was not an option----but I'm old and don't know as much as I used to.
Old 11-14-2011, 07:07 PM   #3
Too Short? Cut it Again!
I've seen products advertised and I suppose with the right contact cement and lots of pressure it could work, for a while. I am not a believer in the concept.
What does the other side of the table look like? Can you take the top off, flip it, laminate the other side and paint the edges with melamine or another paint for plastics?
For that matter, what is the table used for? If it is not all carved up would a couple coats of melamine paint work? Rough up the surface a bit and have at it.
Old 11-14-2011, 07:21 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Go for it!
Coarse-sand the old laminate and apply contact adhesive to both the old and the new and do it. It'll work.
Old 11-14-2011, 09:06 PM   #5
Rewards Points: 268
I actually do a lot of this at work. Sand with 80 grit, clean well, contact cement on both pieces{ no water based stuff} let it dry according to directions and stick it! Roll or otherwise smooth it over and your done
packer_rich is offline   Reply With Quote
The Following 3 Users Say Thank You to packer_rich For This Useful Post:
Bud Cline (11-14-2011), MajorMedicalBoy (11-15-2011), Thurman (11-15-2011)
Old 11-15-2011, 05:04 AM   #6
Rewards Points: 2,238
Just to add to what "packer rich" said -
Note: "no water based stuff"!!!
The non-water based cement is very flammable.
Ventilation!
No Smoking!
rossfingal
rossfingal is offline   Reply With Quote
Old 11-15-2011, 07:17 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
I've done it. Make sure your original laminate is well bonded. Like said above, stay away from water based adhesive. I always use a roller too. Especially around the edges.
Old 11-15-2011, 07:17 AM   #8
Same methods, but slightly different order:........CLEAN the old top with paint thinner, then lacquer thinner then alcohol(ventilate well!!!), that will remove nearly everything found in a kitchen, then rough the surface, vacuum all dust and clean again with alcohol. Then contatct cement.
The Following User Says Thank You to Just Bill For This Useful Post:
ben's plumbing (11-24-2011)
Old 11-15-2011, 10:20 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
^^^^All the above....
One last point...it works as long as your existing laminate it properly attached. If part of it is trying to come up...the top layer will have the same problem.
Pay special attention to the sides......
And look into getting a laminate edging bit for your router to give you a clean edge.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 11-15-2011, 11:06 AM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
Post deleted, old timers ya know.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-15-2011, 12:38 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
jiju1943: "Post deleted, old timers ya know."
Lost your nerve, huh Jim?
Old 11-15-2011, 07:48 PM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
Naw, I forgot he was talking about a table instead of a counter top, and for me that is really easy.
Jim
Old 11-15-2011, 08:11 PM   #13
Household Handyman
Rewards Points: 1,408
Three important words I learned from an older cabinet-maker friend of mine: Scuff, scuff, scuff. The 80 grit sounds good, scuff it up, clean it well, apply the glue properly, allow to "tack-dry" and apply the new laminate. Roll, roll, and roll some more. I've seen him do many older counter-tops and leave them looking like brand new.
The Following User Says Thank You to Thurman For This Useful Post:
oh'mike (11-15-2011)
Old 11-15-2011, 11:00 PM   #14
This method even works in Canada !!
Sammy 2 is offline   Reply With Quote
The Following User Says Thank You to Sammy 2 For This Useful Post:
packer_rich (11-20-2011)
Old 11-19-2011, 12:51 AM   #15
We have a winner
Thanks everybody. The reply that was a help was the idea to turn the surface over to bond a new piece to the bottom. Worked like a charm.
I installed the top first and I think this is a mistake right? Better to do edge first? I ended up cutting into the top a bit trying to flush trim it with the router because I could not find my files. I switched to a 45 chamfering bit and it worked better but it seems to me that it is better to have the top cover the edge.
Wire size for grounding to water meter? WillK Electrical 18 06-15-2011 11:26 PM
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 04:06 PM
Intersystem Bonding Bar zpm Electrical 0 03-08-2011 02:21 PM
can I apply formica over formica? DIYWayne General DIY Discussions 7 12-28-2008 04:19 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
