Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-03-2009, 06:52 AM   #1
Boarding Up Windows on Stucco House
What is the best way to board up windows on a Stucco house? I've seen some houses that have studs sticking out of the stucco so that you could attach plywood & a wing nut but don't like the way it looks.
PearlWhiteGT is offline   Reply With Quote
Old 06-03-2009, 08:49 AM   #2
Old School
Willie T's Avatar
The reverse is the most visually appealing way. No studs. Instead you drill female anchors into the wall. There are a couple of ways you can make them look good (or at least "better") when the cover wood is stored.
1. - Install removable shutters (Decorative fakes) using the same anchor holes.
2. - Just put short, stucco colored studs (bolts) in the hole when they're not in use.
Willie T
Old 06-03-2009, 08:59 AM   #3
Is this a permanent closure or temporary? It would help is the post was a little more detailed as to what you want and why.
Ron
Old 06-03-2009, 09:07 AM   #4
Ron
Temporary if needed for Hurrican season here in South Texas. I will only board up if we are going to get hit by one of them & just want to be prepaired.
Old 06-03-2009, 09:18 AM   #5
Old School
Willie T's Avatar
Here's something to thing about. I don't board up, but a good friend does. He used plywood the first season, and said "Never again!"
Not only did the black house drive both him and his wife crazy, but not being able to see a thing seemed to amplify the sounds of everything outside. At times, he thought the house was coming down, only to open the door to find it was no more than an average storm.
He found a cheap knockoff of Lexan (he tested it with a sledge hammer while it was suspended on concrete blocks... only made tiny surface dents in it.) which he replaced the plywood with. They both love it now. And he just boards up June 1, and leaves it on throughout the season.
Willie T
Old 06-03-2009, 09:45 AM   #6
(the original)
"Plylox" window clips.
ratherbefishin' is offline   Reply With Quote
Old 06-03-2009, 11:06 AM   #7
They won't work on Stucco.
Old 06-03-2009, 11:41 AM   #8
(the original)
Non Destructive -
PLYLOX™ window clips create rigid, safe, temporary attachment of plywood to brick, wood, or stucco
window casings. No nails, screws, bolts or brackets will permanently damage your property.
That's directly from their website
Old 06-03-2009, 12:21 PM   #9
Old School
Willie T's Avatar
I think the two problems experienced with using them on stucco returns has been, first of all, the fact that most older stucco returns (here in Florida, anyway) are not 90 degrees. Many of the window openings tend to bevel outward. This all but defeats the Plyloc design function.
Secondly is the possibility of a weaker stucco mix, allowing the flexing of the plywood to cause the sharp edge of the Plyloc to wear a groove in the stucco.
I haven't heard of any total failures, but I wouldn't trust the design on anything but a square, 90 degree return.
Willie T
Old 06-06-2009, 08:34 PM   #10
(the original)
Ahh.....hadn't run into that, makes sense. Thanks, Willie T.....good info. Hopefully none of us will need to use it this year
Old 06-07-2009, 08:44 AM   #11
Old School
cabinetman's Avatar
This may sound a bit archaic, but how about screwing to the face of the plywood a vertical strip of something like 3/4" x 2", and mount them with some close proximity to the sides of the stucco so wood wedges can be tapped in the gap to tighten to the opening.
cabinetman is offline   Reply With Quote
Old 06-07-2009, 10:28 AM   #12
Kbk graphicx not recommend
NOT KBKGRAPHIX is offline   Reply With Quote
Old 06-07-2009, 10:32 AM   #13
Thumbs down
KBK GRAPHIX NOT RECOMEND
Old 06-07-2009, 10:45 AM   #14
Hello Keith, In response to your last email (sent 5.19.09 I've attempted to contact you several times via email and phone, but to no avail
PAY YOU OFF AND I HERD ABOUT YOU ANY MORE
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Stucco exterior walls - how to properly install doors and windows? vsheetz Carpentry 3 02-01-2009 11:47 PM
Soundproof windows jlleonard General Discussion 2 08-06-2008 02:01 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 01:44 PM
