Blown Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 11:39 PM   #1
Blown insulation
I bought a older house (1954) last year and the previous homeowner had put blown in insulation in the attic. thickness varies from about 6" to 15".
well the problem is that the lights in the house are im sure NON-IC rated. and the insulation was blown in over all the old wiring that is ran through the attic (which I was lead to believe is not right).
the house when i bought it had a horrid roof on it and was leaking slightly into the attic so i know that there area a few spots in the attic that have gotten fairly wet (based on the water spots in the plaster).
so all that being said.. I planned doing significant work up there replacing/moving/taking out some lights. repacing a few rafters
I figured while doing this I should just rewire the attic area right now.
now to the question is there a FEASIBLE way to remove blown insulation or move it to one side of the attic while I do the work in the other side. or what would be the best way to go about getting work done up there?
Xtreme_99 is offline   Reply With Quote
Old 01-05-2009, 06:56 AM   #2
Wires are not a problem under insulation, but insulation too close to non-IC lights can be. And rewiring would not be simple. All splices must be in a J-box, and most wires come up/down thru walls. From an energy standpoint it is better to replace the lights with IC or airtight fixtures. Or pull the insulation away from the fixtures.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
old blown insulation djknob Building & Construction 3 12-29-2008 12:20 PM
blown in insulation? ponch37300 Building & Construction 16 02-29-2008 10:00 AM
Vapor Barrier & Blown in Insulation barbe4 Building & Construction 1 12-03-2007 09:05 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
