Black U-Bolts? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-09-2010, 03:13 PM   #1
Black U-Bolts?
Hello, I am currently working on a sort of special project where I need two U-bolts. I'm not sure of the exact measurements at the moment, but I would guess that they need to be about 4" in length. Maybe 3". Anyway, my question is, does anyone know where I could find some U-bolts that are black? Or maybe even covered in a black plastic? I just have to put them into a location where things might scrape up against them, and I need them to be black. I can paint them, but I'm worried they'd get scratched and I'd have to constantly re-paint black.
So, anyone know where I could find such a thing? I looked at local hardware stores and all they have are typical silver U bolts. Let me know if anyone has any ideas.
markronz is offline   Reply With Quote
Old 03-09-2010, 04:00 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what size of U-bolt as in, what diameter round stock are they needed to saddle?
you mentioned a length but I am not sure what actual dimension you are referring to with that.
and depending on what they are being used for, it might make a difference as to suggestions for a black u-bolt.
Old 03-10-2010, 02:58 AM   #3
Rewards Points: 410
If a Black Oxide finish will work for you , then here you are.
http://www.grainger.com/Grainger/u-b...rch&sst=subset
High Gear is offline   Reply With Quote
Old 03-10-2010, 07:53 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... Slip a piece of hose or tubing over it, before it's assembled...
Bondo is online now   Reply With Quote
Old 03-11-2010, 03:29 PM   #5
Sorry for not posting back about this sooner...
Also, sorry, I didn't (and still don't yet) have the proper measurements you were asking for. The reason I don't know these things is because I am using these U rings as holsters on the sides of an arcade machine to hold the plastic guns there. See the attached pictures. On my first arcade I made, I just painted them U-rings from the store black. It works ok, except they get all scratched up from the inserting and removal of the guns.
So it's not exactly the standard use for a U-Ring, so that's why I was referring to it in inches instead of pipe size, sorry.
I was thinking just like about 2 inches between the two bars, and then the bars of the U needed to be about 3 or 4 inches long.
Black Oxide would probably be fine. I will have to check the measurements to see if any of the ones you linked would work.
Regarding the hose or tubing idea, what exactly did you mean by this? U-bolts are really thin, and I'm not sure where I would find black tubing that would fit over that specific size....
Thanks for any help anyone can give me.
Old 03-11-2010, 04:16 PM   #6
nap
You talking to me?
nap's Avatar
how about this:
link
Old 03-11-2010, 06:51 PM   #7
That link didn't work, but I did find Black Vinyl Tubing elsewhere. They might even have it at the store in the gardening section. Now I have something to base this on when I go to the store to look! Thanks a lot!!!
Old 03-12-2010, 12:49 PM   #8
Just as a suggestion,You could go to menards and get a holster that you use for screw guns on a tool belt. With a little modification, it might look pretty good and protect the Gun
antlerdancer is offline   Reply With Quote
Old 03-12-2010, 04:08 PM   #9
Bondo's Avatar
Rewards Points: 650
Ayuh,... Any quality Hardware Store will have several flavors,+ colors of plastic Tubing in their Plumbing section...
3/8" Pex would give a flash of Color,+ easily fit over a 5/16" u-bolt....
5/8" Pex will slip over a 1/2" u-bolt...
U-bolts themselves are probably available at the same store...
Exhaust clamps for autos are another option, although they'll be plain ole steel,...
The Hardware Store should have 'em cadium plated,....
Old 03-12-2010, 07:16 PM   #10
OR,
paint the U-bolt black...
cover with clear plastic tube... easy to find in size you need.
Then Replace tubing when worn & machine has made you $ 5K
Please send commision check to NATHAN...
Big Bob is offline   Reply With Quote
Old 03-12-2010, 08:12 PM   #11
DIY staff
Rewards Points: 7,174
I like the tubing idea the best--however--There is a product for coating tool handles,I think one brand is Plasti-dip. That would work but might be pricey.
Old 03-12-2010, 08:16 PM   #12
Rewards Points: 5,336
They have something called heat shrink tubing you use for electric connections. It comes in various widths to accomodate different wire guages.
There's also a product that is used to insulate the handles of pliers that is a viscous liquid plastic. You dip the handles into it and it coats the metal. Numerous coats can be built up to get to the required thickness.
I can't remember the name, but "Liquid Plastic" rings a bell.
Ron
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Leaking tank bolts splinters Plumbing 4 12-25-2009 07:04 PM
Black Iron Exposed? jamiedolan Plumbing 0 08-14-2009 11:16 AM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 10:53 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
