Black Tar-like Glue On Basement Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 10:44 AM   #1
Black tar-like glue on basement floor
I have tried to remove black sticky tar from the cement floor in basement so I can paint the floor with the new basement paint with chips. I cannot get the glue up. Scraped, used paint thinner, other chemicals and it just turns into a sticky mess, black and guey.
I want to paint it not lay down another floor. Have any ideas? Thanks,
diyinohio is offline   Reply With Quote
Old 12-19-2008, 11:09 AM   #2
Registered User
Termite's Avatar
The glue used to lay thin (often asbestos) tiles back in the 60's and earlier often had asbestos in the glue as well. I don't know of anything that will take that glue off effectively except grinding the floor down, but if the glue has asbestos that would be a horribly bad idea.
Old 12-19-2008, 12:21 PM   #3
Get some methylene chloride based paint stripper. Put it down and scrap off after about 10 minutes. You'll probably need to do this several times but you should be able to get almost all of the glue off.
Make sure you have good ventilation as methylene chloride is very smelly.
Dorkgeez is offline   Reply With Quote
Old 12-19-2008, 12:50 PM   #4
Oldguy
Rehabber's Avatar
Before you use methylene chloride, try lacquer thinner I have run into this stuff before and it came right up. Just be very careful with the fumes.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-21-2008, 02:23 AM   #5
Rewards Points: 602
Will laquer thinner work better than concentrated adhesive remover? I used the adhesive remover (and a steel brush) on the same kind of black stuff under carpet I pulled up in the basement a few years ago and had to apply it several times, but still didn't get it all off.
gma2rjc is offline   Reply With Quote
Old 12-21-2008, 03:32 AM   #6
Oldguy
Rehabber's Avatar
The last time I used it, about 95% came up with the first application, the rest with the second. I did about 9 sq feet at a time.
Old 12-21-2008, 03:46 AM   #7
Rewards Points: 602
It does work better than adhesive remover then. I worked in 3' square sections and had to pour it on, let it soak in and scrub with the steel brush at least 3 to 4 times. The black stuff I was removing wasn't sticky to the touch, but it was just like tar.
Old 12-21-2008, 12:23 PM   #8
Rewards Points: 5,336
It's an asphalt based adhesive used to to adhere tile back in the '50's and '60's.
Ron
R & R basement floor ? SAGENT Building & Construction 6 10-26-2008 12:55 AM
Basement Floor options NashvilleKat Flooring 11 04-19-2008 10:45 AM
Can floor jacks in basement be permanent? ragtopdave06 Remodeling 15 03-15-2007 05:23 PM
