Birds Building Nest Under AC Unit - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 11:47 AM   #1
Rewards Points: 900
Birds building nest under AC unit
Hi;
I have had the problem with birds building nests under my window AC units.
They can get in and out due to the large openings around the storm window where the AC passes through.
My solution so far has been stuffing window screening (the old, steel type) into the opening. That seems to work pretty well, but is a hassle to install.
I'm wondering whether there is any product that would fit onto the AC unit and close off the opening, while at the same time allow the air to circulate around the unit's vents.
Unfortunately, I cannot get access to the window units once they are installed, as they are on the 2nd floor.
If I could fit something onto the AC before sliding it into the window, I think this would do a better job, and be much easier to use/install.
Any ideas?
FW
Ultrarunner2017 is offline   Reply With Quote
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 08:51 PM
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
Replacing inside air control unit - have to replace outside as well? yalej HVAC 2 04-29-2009 11:46 AM
Thru-The-Wall AC unit Ultrarunner2017 HVAC 30 04-26-2009 07:58 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
