Big Problem With Screwing A Bracket To Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-03-2007, 08:39 PM   #1
Big problem with screwing a bracket to drywall
I recently purchased some bookcases for the living room of my apartment. The shelves are pretty tall and have a bracket that holds the shelves flush against the wall. I got some drywall anchors, but for some reason they weren't working. Some exploratory drilling later, I've come to the conclusion that there's some kind of solid concrete or something barrier immediately behind the drywall which is preventing the drywall anchors from going deep enough. I tried screwing directly into the whatever, but that didn't work either. As far as I can tell, this concrete or whatever is behind all of the wall that I want to put the shelves on. Does anyone have any suggestions as to how I can anchor these bookcases?
bobman0330 is offline   Reply With Quote
Old 11-03-2007, 09:43 PM   #2
Rewards Points: 6,652
Most likely a Firewall between units. You could use a Concrete bit to allow you to drill a hole deep enough to insert an expanding anchor that is used for concrete walls.
Old 11-05-2007, 09:54 PM   #3
Spyko's Avatar
Tapcon screws
Tapcon makes concrete screws. A box of screws comes with the proper drill bit for them. Make sure there are no pipes or wires where you're drilling!
Spyko is offline   Reply With Quote
Old 11-06-2007, 10:44 AM   #4
Rewards Points: 1,910
You'll need a hammer drill for the tapcon drill bit.
BTW do you have the ok from the landlord?
Old 11-06-2007, 01:35 PM   #5
It's not essential. Especially for the couple screws he's installing. A regular drill will be a bit slower, but perfectly adequate for drilling the holes.
NateHanson is offline   Reply With Quote
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
screwing in drywall by hand? yummy mummy Building & Construction 22 11-08-2006 11:20 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 07:24 AM
Drywall problem LEudaly Building & Construction 1 05-07-2006 01:57 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
