Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-21-2012, 11:51 PM   #1
Big draft behind vanity
Recently had plumbing work done and he redid the plumbing behind my bathroom vanity...im getting a serious draft coming from this hole, the wall is tiled, so any ideas of a quick fix to stop this draft!? Attached is a picture...
Ckb3216 is offline   Reply With Quote
Old 01-21-2012, 11:59 PM   #2
Looks like he used an M80 to make that hole.
First I would go under the house in that area and seal up the holes through the bottom plates with high expanding foam, then about all you can do now is stuff fiberglass insulation in that hole.
Old 01-22-2012, 12:01 AM   #3
Im on a slab and this bathroom is on my bottom floor
Old 01-22-2012, 12:03 AM   #4
Where does that drain pipe come from and where is it going.
Old 01-22-2012, 12:06 AM   #5
Comes from upstairs bathroom and runs to the left and out of the house into sewer...to the left outside and behind this wall on otherside is my kitchen
Old 01-22-2012, 12:07 AM   #6
Im sorry it doesnt go left it goes right into the slab and out
Old 01-22-2012, 12:19 AM   #7
Strange to have a breaze in an inside wall. I'd be looking in the attic around where the vent goes through the top plate for a gap that needs foam around it. The falling cold air from the cold attic may be it.
oh'mike (01-22-2012)
Old 01-22-2012, 05:54 AM   #8
creeper's Avatar
I just had an energy audit performed and that is the exact spot that I was told to fill with insulation. I was told it is totally normal. I was also told to install safety plugs in unused outlets. Even the ones on inside walls
creeper is online now   Reply With Quote
Old 01-22-2012, 06:35 AM   #9
biggles's Avatar
cold air is just dropping down and hitting the hole slab adds to the temp also.a spray can of foam HD/LOWES start in the back and foam it out go slow cause that stuff expands super fast and sets.old rag stuff in there for now
Old 01-22-2012, 09:08 AM   #10
No attic..
Old 01-22-2012, 09:17 AM   #11
Never heard of an energy audit that called for safety plugs in outlets, sure they did not mean foam die cut outlet covers that go behind the covers of outlets and switch covers?
Old 01-22-2012, 09:19 AM   #12
Yeah prob, i put those around my house i have such a drafty cape.
Old 01-22-2012, 12:38 PM   #13
I have about 2 ft from slab to where i am foaming, being im in the wall the foam wont sit, any ideas what i can use to prevent the foam from dropping into the wall??
Old 01-22-2012, 01:15 PM   #14
creeper's Avatar
Joe: both the foam backs and the baby covers will work
Old 01-22-2012, 04:54 PM   #15
Spray foam is now my new best friend.
How to build/attach wall hung bathroom vanity NewHomeDIYGuy Carpentry 13 12-28-2011 03:17 PM
Building HVAC vent into bath vanity nolamar Carpentry 31 08-25-2011 03:33 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 05:56 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 02:12 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
