Bi-folds 47 1/2" Opening - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 08:26 AM   #1
I'd like to replace my existing metal bi-fold closet doors with wooden doors. The opening is 47 1/2". Will 2 24" bifolds work in that space. I know the math doesn't work, but I didn't know is 24" doors were actually 24" wide. I'd measure myself at the store, but I have to order online. Thanks
Rg2277 is offline   Reply With Quote
Old 03-07-2011, 08:54 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Sometimes a 24" door is 23-3/4" .....sometimes it's 24"
Worse case, you may have to shave off some of each door to make them fit.
The stiles (vertical frame members) are typically 1-1/2" wide and if you take an 1/8" off 2 sides of 4 doors, you can get a whole inch off the overall width of the doors.
Hope this helps
tcleve4911 is offline   Reply With Quote
Old 03-07-2011, 11:10 AM   #3
Rewards Points: 5,336
Whether you order online or go to the store, you still need to know the size of the finished opening. The doors you buy need to fit into that area.
Doors are modifiable. Some more then others. Flush doors the most. Louvered doors the least.
Ron
Old 03-07-2011, 07:54 PM   #4
Rewards Points: 83
I have a feeling that they won't fit. Or at least won't work properly. 48" finished opening is standard, maybe even an 1/8-1/4 over that. But like they said, pretty easy to rip a bit off. If you do have to cut them, if you put some painters tape on the area of the door that the base of the circular saw, or table saw is going to rub, it will stop the door from getting scratched up.
rubberhead is offline   Reply With Quote
Old 03-08-2011, 01:44 PM   #5
Thanks for the info! I'll probably end up ripping them since I'm not looking to get/pay for custom doors. I'll let you know how it works out
creating an opening bearing or not? Wiscbldr Building & Construction 2 11-01-2010 02:32 PM
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 03:46 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
Opening for attic stairs sk8z Remodeling 16 03-17-2008 12:52 PM
