Best Way To Secure Ladder To Ladder Rack? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 10:21 PM   #1
Rewards Points: 85
I just got new ladder racks (front of bed and back of bed) for my '96 Toyota Tacoma. What is the best way to secure a ladder to the racks? Right now I use two ratcheting tie-downs, securing one around the front of the rack & ladder to the loop welded on the bed, and another one around the back of the rack & ladder securing it the same way as the front - securing it to the loop welded on the bed. This is certainly effective for me, as the ladder doesn't move AT ALL. However, I'm always looking for better ways to do things, so maybe you guys have special ways that you tie your ladders down, i.e. perhaps some special way with only one tie down, etc. Thanks!
Chris Sweeney is offline   Reply With Quote
Old 10-08-2012, 10:35 PM   #2
Rewards Points: 12,846
I've been just using 3 adjustable bungie cords for the past 15 years, fast simple, cheap, no rusted or stuck racket to worry about. I've never lost a ladder yet,
I see electritions using a short piece of 14-2 wire all the time. Works great, a couple of twist and it's not going to move.
http://www.amazon.com/Adjustable-Bun...le+bungee+cord
Old 10-08-2012, 10:58 PM   #3
Rewards Points: 2,202
Seen everything from rope, bungee straps, ratchet straps, 14/2 wire, big twist tie things, to fancy built in clamps.
mae-ling is offline   Reply With Quote
Old 10-08-2012, 11:14 PM   #4
Rewards Points: 558
You can use this:
I myself have always used rope to tie down.
epson is offline   Reply With Quote
Old 10-09-2012, 05:39 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Bungy cords will generally work with most typical ladders and extension ladders.
Larger and heavier extension ladders and things like pump-jacks are safer/secure with ratcheted tie-downs (especially due to their length = and the tendancy for them to sway & see-saw on the highway).
The key point is downward tying (very, very tightly) = you want the ladder tied as tightly as possible with downward force using the bungy (or other tie-down methods).
Tip: Always protect your eyes & face when undoing tightly secured bungies. I cannot tell you how many times I have seen people hit in the face with the end of bungy that is being unhooked.
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
mae-ling (10-09-2012)
Old 10-09-2012, 06:54 AM   #6
custom user
Rewards Points: 150
I use the rubber bungies but double up on them, just in case one breaks. I inspect them too because they will start cracking as they age.
Motorcycle ratcheting tie downs for the big stuff (plastic coated hooks).
JasperST is offline   Reply With Quote
Old 10-09-2012, 06:55 AM   #7
kwikfishron's Avatar
Rewards Points: 86
Whether it's lumber a ladder or Granny's rocker if it's on my rack it's secured with ratchet straps.
I wouldn't trust bungies in a wreck.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 10-09-2012, 08:20 AM   #8
custom user
Rewards Points: 150
If a wreck is severe enough to break four stout rubber straps on a relatively light piece of equipment then there are going to be much bigger problems.
Old 10-09-2012, 06:27 PM   #9
Rewards Points: 86
I agree, and all the more reason for one less flying projectile.
Old 10-09-2012, 07:52 PM   #10
Davejss's Avatar
Rewards Points: 740
I'm a twisted cable fan. A few feet of 14/2 and quick twist makes a fast, secure, simple tie down.
Davejss is offline   Reply With Quote
Old 10-09-2012, 08:50 PM   #11
custom user
Rewards Points: 150
Do you secure everything in your car and truck? There are number of things that can go flying in a wreck, including my dogs. I'm not strapping down everything every time I take anything on the road, period.
Old 10-10-2012, 07:14 AM   #12
Rewards Points: 85
Wow, thanks guys, all the suggestions and points you guys make are great. I guess I'll stick with the tie downs for now. I'd hate to get in a wreck and have my ladders all come flying off, potentially causing all sorts of other accidents. Those Hook-Um Dano ladder locks look awesome too, but for $65 a pop, I might just stick with the tie downs.
Old 10-10-2012, 08:13 AM   #13
biggles's Avatar
with the ladder set on the rack couple of L brackets bolted into the rails...one above the passanger side (if the ladder is on that side) to stop foward motion.then for side to side add one each about a foot or so down(front/back) the rack to stop sliding....about 1/2" off the ladder,and if possible a second bend 2"-3" on the side L bracket will hold it down.i'v done this on a 250Ford van for years and had total confidence on that rack...strip of armaflex on the rack rails will stop that tapping that will drive you crazy while driving... lenghts of solid wire are the best tie down set up
Top rack is not getting any water RPellecchia Appliances 1 10-24-2011 09:42 AM
New ladder advice kathyll Building & Construction 4 07-11-2011 12:29 PM
Random GFCI tripping, Data Rack theatretch85 Electrical 5 07-10-2009 09:20 PM
