Best Way To Seal Exposed Insulation On Interor Wall? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 10:44 AM   #1
Best Way to Seal exposed insulation on interor wall?
See diagram below. I'm trying to figure out what to do with the unfaced side which is exposed to my storage area (2nd floor cape cod).
I think the best idea is to nail/glue polystyrene to this side to add additional insulation and prevent me from getting itchy every time I crawl into the storage to pull something out. Is there something easier that I can simply staple onto the wall? (Like a vapor barrier or insulative "blanket")
chazman113 is offline   Reply With Quote
Old 10-08-2010, 01:57 PM   #2
Rewards Points: 3,130
Your insulation is installed backwards. The vapor barrier should be on the warm side. But to answer your question, staple up some 6-mil poly and tape the seams.
Old 10-08-2010, 02:05 PM   #3
Vapor barrier is on warm side, the side that has the drywall in the bedroom. The exposed side is in an area for storage that is "insulated but not heated".
Old 10-08-2010, 04:51 PM   #4
Rewards Points: 5,336
Put down a plywood floor.
Ron
Old 10-08-2010, 04:52 PM   #5
Registered User
Rewards Points: 5,266
House wrap or rigid sheathing material on the attic side of the knee-wall insulation protects the insulation from wind washing:Fig.4: http://www.buildingscience.com/docum...archterm=insul
Gary
Old 10-08-2010, 04:58 PM   #6
I have plywood floor down, referring to the non-drywall side of the interior wall. I'm thinking I'm just going to use house wrap on it
Old 10-08-2010, 07:12 PM   #7
Chicago, IL
Michael Thomas's Avatar
Whatever you punt on the other side of the kenn w
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-08-2010, 07:56 PM   #8
In the words of chris tucker on the movie rush hour, "What the hell did you just say?"
Old 10-09-2010, 04:32 PM   #9
Registered User
Very hard to type while riding a Segway.......
Gary
New Unfaced Insulation Off gassing something common sense Building & Construction 3 10-07-2010 04:46 PM
super insulation retrofit with rigid insulation hostaking Building & Construction 5 01-07-2009 11:23 AM
Rigid Insulation Exposed timchi29 Remodeling 3 11-07-2008 01:52 PM
Insulation of pex tubing? user007 HVAC 2 12-21-2006 10:44 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
