Best Way To Repair Broken Blinds - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 04:27 AM   #1
Best Way to Repair broken blinds
So I was vacuuming my room in my apartment the other day and a gust of wind knocked the string to the blinds onto the floor and right in front of the vacuum. Needless to say, it ate up the cord and the blinds came crashing down with it. They were snapped pretty well in half right at the joint where the string is held. It seems to be a relatively easy fix as it was a pretty clean break, but I'm at a loss as to what the best method would be. I thinking a glue, but what kind of glue would be able to hold the stress of pulling up and down constantly (of course I would be gentler with these than the other set.
Thanks!
C_Miller is offline   Reply With Quote
Old 08-20-2010, 06:55 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
C, Welcome to the Forum
You could try patching with
Scotch Mailing Tape
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-20-2010, 08:37 AM   #3
Old School
Willie T's Avatar
In reality, a ragged break where the pieces have some angled overlap is much easier to fix with just glue than a clean snap break. Usually with a sharp break like that, you have to add external layers to provide some sort of overlap.
I would just replace the broken slats. It's a pain, but if you work slowly and let yourself absorb the way the cords in the blinds run and how they operate, it CAN be a DIY......... but not the easiest one you'll ever do.
Willie T
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Replacement Windows - Pella, Anderson, Marvin? The what to do about blinds? ms_obvious General DIY Discussions 3 11-29-2009 09:16 AM
repair of broken dwv line from kitchen to the main. docwatson Plumbing 8 05-06-2009 12:14 PM
How do I repair a broken towel rack that was attached to the tile? meganprncss General DIY Discussions 2 05-03-2009 10:40 AM
