Best Way To Move Pallete's From Front Of House To Backyard - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 04:38 PM   #1
Rewards Points: 143
Question
Best Way to Move Pallete's from Front of House to Backyard
Hi everyone, I was hoping to get some advice. I just had a shipment of stones delivered to my place. The truck driver said he couldn't get his truck onto my driveway and/or the grass to boom the stones into the yard. I need to get the stones off the front lawn (about 10 pallets) in the most cost effective manner.
Anyone have any ideas? I thought about a pallet jack but seeing that the pallets are on the cold ground/lawn I think the pallet jack would simply sink into the ground.
cloves is offline   Reply With Quote
Old 12-12-2009, 05:18 PM   #2
Like they moved the stones for The Pyramids; several tree trunk sections under each pallet, move the sections from behind the pallet to the front while your helpers push. Softer ground needs larger diameter sections and a bigger whip for your helpers.
Watch your toes.
When you're done, split the wood and burn it in your fireplace.
Old 12-12-2009, 05:46 PM   #3
Wood Butcher
robin303's Avatar
I do rock work in the hill country and have the same problem and this is what I do:
wheelbarrow
Bobcat, Rent one for one day. Costs me about $135 delivered
robin303 is offline   Reply With Quote
Old 12-12-2009, 06:08 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,370
Ayuh,... Robin beat me to it,.. Wheelbarrow...
Maybe a Mason's barrow if the stones are squarish....
Rental skid-steer or some sorta tractor is an good idea...
Old 12-12-2009, 06:29 PM   #5
Rewards Points: 143
Thanks for the suggestions so far guys. I actually moved 3 pallets using the trunk of my suv and it took like 6 hours and my hand and back are shot today.
A friend mentioned a bobcat, does that thing normally come with the fork lift teeth attachment? I have only seen bobcats with the digger attached. Same goes for the skid steer.
If i can rent either and be able to fork lift the pallets well worth it.
Old 12-12-2009, 06:40 PM   #6
Wood Butcher
robin303's Avatar
I'm sure you can get any attachment you ever wanted. Usually I just dump the rocks in the bucket and dump or spread the rocks to the area needed. The reason I do that is you can spot the rocks you need as you go along. What kind of work are you doing.
Old 12-12-2009, 07:23 PM   #7
Rewards Points: 143
I should have mentioned its pavers for a patio instead of stone. I am going to call up the local rental place up here see what they charge.
Old 12-12-2009, 09:56 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Don't you have any kids?
Dang, that is the biggest reason I had any kids at all.
slave labor
Oh, and a Bobcat is a name brand of a skid steer loader and there are forks available for use with them. You will want to have an approx weight of the pallet of pavers. The skids do have their limitations.
Old 12-13-2009, 01:53 AM   #9
Rewards Points: 143
Ahhh, thats a good point. I am going to have to find out what one of the pavers weights and then multiply that by the amount on the pallet. So I need a skid steer with forks.
Old 12-13-2009, 04:29 AM   #10
Too Short? Cut it Again!
[quote=nap;365774]Don't you have any kids?
slave labor
/quote]
I love this idea and am looking forward to seeing pictures and videos of how it works out. Slaves, as those described near me, tend to rebel or otherwise loose enthusiasm from my experience even with threats of witholding food, car keys, and being totally cut off from an imagined immense and wealthy estate that might be theirs some day. Some I know would do it but not with the pace even legal immigrants from Labor Ready would for minimum wage. Hint. Hint.
You should be able to get a pallete handling thing for a bobcat type tractor if you have room to move it around the yard. Wheelbarrows and slave labor would actually be a better choice though since you have to break the bricks off at some point anyhow? Dragging palettes of bricks is going to have to tear your yard apart on the way with a tractor. Lot of weight all at one time on the palette and the bobcat?.
Call the labor temp agency in your area? The guys will have those bricks unloaded and restacked where you really want them in no time. Or, rent a field capable forklift for about the same amount of money and be done with this? Trust me the wheels on anything capable of moving palettes of bricks is going to carve a groove or two in your yard.
Old 12-13-2009, 08:08 AM   #11
Rewards Points: 1,016
Temp labor or day laborer service - I use one often when I need someone younger and skinnier than me.
Old 12-13-2009, 08:53 AM   #12
Usually these are pretty heavy pallets
If the ground is soft at all a machine may sink in
I looked into picking up pavers with my F150
But at 1/2 pallet at a time due to weight it wasn't worth it (saving delivery fee)
I had them delivered & made sure they had the right machine to deliver to the back yard
All of my lumber deliveries have had one of these on the back of the truck
One was even able to load the lumber sideways to put it into the garage
The bobcat forks have different weight ratings...around 1800 & 3400 lbs
You will probably need the ones that handle the greater weight
Find out how much a pallet weighs before attempting this
Old 12-13-2009, 09:39 AM   #13
150 #/cu. ft. x 27 cu ft. = 4100#.
Old 12-13-2009, 03:18 PM   #14
Let me guess, you ordered from menards.
I ordered 1500 retaining wall blocks. 15 different plallets. I told them I wanted in the backyard and paid the extra 150 for that service. They show up with a semi thinking it can get into a back yard. I made them go back and figure out a way to get it in my backyard. The guy said I could just carry them. I asked him why then would I pay 150 dollars for you guys to put them where I want them. Ill just cancel the order and find someone who can do it for me.
In the end - the 4000 dollars was worth figuring out a way to get it done.
BamBamm5144 is offline   Reply With Quote
Old 12-13-2009, 05:15 PM   #15
Safe, Most of the Time!!
brokenknee's Avatar
Most rental companies will have the fork attachment for the skid loader. Here is a picture of what they look like, they are on a quick attachment plate that attaches were the bucket would go.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
