Best Way To Join Pipe Without A Fitting? - General DIY Discussions - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 06:15 PM   #31
Rewards Points: 264
Originally Posted by sdsester View Post
I don't get it.
It's a pipe, with pipes sticking out of it...
tibberous is offline   Reply With Quote
Old 11-15-2012, 07:47 PM   #32
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
I don't get it.
For a growing operation......
ddawg16 is online now   Reply With Quote
Old 11-15-2012, 09:32 PM   #33
would a 4x2 saddle work for you?
http://shop.mccoys.com/plumbing/pipe...ttings/p.22462
http://www.ronshomeandhardware.com/4...t-p/745109.htm
6-10 dollars each
Old 11-16-2012, 07:24 AM   #34
Rewards Points: 1,686
The most economical way may be to research pipe saddle templet. After that begins to put the nerves on edge take a short piece of your 2 and 4 inch pipe to a reputable welding shop that may already have a templet for that size of pipe. The process would be to cut the end of the 2 inch pieces to saddle the 4 inch using the templet as the pattern and then do the plastic welding.
Join 100mm pvc pipe to a concrete tank sosza Plumbing 5 07-24-2011 04:11 AM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
