Best Way To Install Bathroom Fan Vent Through Exterior Wall?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-08-2008, 09:04 AM   #1
Rewards Points: 324
Best way to install bathroom fan vent through exterior wall??
Im working on finishing my basement and I need to vent the bathroom fan through an exterior 2X6 wall that has vinyl siding out the outside. Obviously I could hack it up with a sawzall but I am looking for some hints or tip on the correct/best way to cut the hole in the siding and seal the vent up correctly. Keep in mind I live in MN and its cost out so the siding is probably brittle.
I picked the typical vent such as below, in the 3 inch variety.
tigerbalm2424 is offline   Reply With Quote
Old 01-08-2008, 09:14 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,.......
When I did 1 like that, thru Vinyl siding,.....
I used a holesaw,+ ran it Backwards to make the cut.......
'course is Slower that way, but less likely to Hang,+ Rip the siding......
Bondo is online now   Reply With Quote
Old 01-08-2008, 09:22 AM   #3
Rewards Points: 324
Originally Posted by Bondo View Post
Ayuh,.......
Sounds good. Then did you just install the vent and caulk around its lip directly to the siding? Did you have to peel off any pieces of siding to get it through the hole or did you make the hole larger than the square section? Didn't know they make 4" hole saws!
Old 01-08-2008, 11:53 AM   #4
they do, they're just really $$$ ... was at home depot and I think they were going for $60+
njchan is offline   Reply With Quote
Old 01-08-2008, 12:51 PM   #5
Rewards Points: 324
Yeah, I just left HD and they arent worth the money for one job. Looks like its sawzall for the sheething and dremel for the siding!!!!
Old 01-08-2008, 06:43 PM   #6
Rewards Points: 5,336
One issue with the siding is that the housing of the vent will not sit flat on the siding. The siding, depending on exposure will be 2",4",5", etc. Try installing a composite block where the vent will go so it will sit flat against the house. You can wrap it in "J" channel and caulk it if necessary to seal it against the weather. Sliding ice and water shield under it would be even better.
You also hide the sawzall cut hole from the outside.
Ron
Old 01-08-2008, 07:19 PM   #7
Rewards Points: 324
Ron
If you wouldnt mind, can you elaborate a little more?
1. Can you post a picture of what a composite block looks like and how I would use it? (where it would go). Im having trouble picturing this. How does it coinside with with vent? Where does the ice and water fit in?
Thanks again!
Old 01-08-2008, 10:55 PM   #8
They sell wood/plastic boards that are used for fascia. They are 1x6 or 1x8. You fabricate a square piece of this and use it as a template. You cut out a square piece of siding, cut the hole for the vent and install the ice and water shield against the sheathing and install the flat composite board over the ice and water shield. Now you have a flat surface to install the vent against.
If you go outside with the vent, you will see that it will probably not sit flat against the house due to the siding profile.
What profile is the siding?
Ron
Old 01-09-2008, 06:47 AM   #9
Rewards Points: 324
Ron
Ahhhhhhhhhhh. I get it now. Thanks! You are correct, the profile of the siding is not straight.
vent bathroom fan to furnace vent jcrampton HVAC 16 10-12-2012 12:24 AM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
Vent in the Bathroom art2670 HVAC 9 07-18-2007 01:10 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 10:45 PM
