Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-09-2011, 12:51 PM   #1
Best way to fix leak in wall
The pipe to my shower head is leaking inside my wall and I'm trying to figure out the best way to go about fixing it. The bathroom shower/tub is the one piece molded type and it sits against the outside wall of my house. Trying to figure out if I should go from the outside or inside of the house to repair the leak? The house has vinyl siding so no brick to deal with and I have no idea how long it's been leaking as it leaks on the outside of the house. I'm just trying to figure out the best way to approach this and the most cost effective way.Thanks
jas89tta is offline   Reply With Quote
Old 05-09-2011, 01:13 PM   #2
Learning by Doing
Leah Frances's Avatar
Ugh. Me too. Except my leak is between 16 inches of brick wall and a wood paneled wall.
Can't go through the brick (unless I get my big hammer drill out ) so I'm getting out my crowbars and saws this afternoon.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-09-2011, 01:15 PM   #3
Coconut Pete's paella!
CoconutPete's Avatar
I'd pull the shower piece rather than dealing with pulling the siding and cutting the wall, but that's just my opinion.
CoconutPete is offline   Reply With Quote
The Following User Says Thank You to CoconutPete For This Useful Post:
VIPlumber (05-09-2011)
Old 05-10-2011, 12:15 PM   #4
Household Handyman
Been there, done this. Pulling just enough of the vinyl siding and cutting a square hole in the exterior sheathing is not as hard as you may think. Removing a one-piece tub/shower unit and replacing this is no easy task at all. After removal of the siding, you may only need a whole 36" square to have plenty of room for inspection and working area.
Can I remove this wall..? (Image) findlay70 Building & Construction 8 04-27-2011 06:02 PM
leak in my wall benluz Plumbing 1 01-29-2011 08:05 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Bathtub faucet leak in wall seabreezz Plumbing 3 02-15-2009 12:59 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
