Best Wat To 'unsieze' A Rusty Hinge - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 01:41 AM   #1
Best wat to 'unsieze' a rusty hinge
Best way to 'unsieze' a rusty hinge
So I've tried WD40 but the only way it will move is if I bash it with a hammer.
I seem to recall my father long ago soaking stuff in kerosene. Will this help?
Wandererone is offline   Reply With Quote
Old 04-16-2012, 07:09 AM   #2
DIY staff
Rewards Points: 7,174
Mild acid (like a toilet bowl cleaner) will help--then clean with soapy water and oil it up---
Old 04-16-2012, 07:17 AM   #3
PB Blaster or a similar rust penetrator. I use Kroil all the time on old Chevys.
Old 04-16-2012, 08:12 AM   #4
Too Short? Cut it Again!
Naval Jelly or something like Liquid Wrench but you will have to clean it up afterward.
Old 04-16-2012, 08:15 AM   #5
joed's Avatar
Rewards Points: 11,576
Keep oiling it and keep moving it. Soaking kerosene might help.
Heat could be of assistance also. Be careful the WD40 is very flammable.
Old 04-16-2012, 09:08 AM   #6
Learning Things Every Day
Jay 78's Avatar
+1
It's handy to have on hand, especially here in Michigan where every vehicle starts developing the cancer after a few years....
Under Construction
Jay 78 is offline   Reply With Quote
Old 04-16-2012, 04:03 PM   #7
Rewards Points: 338
+1 on the pb blaster. anyone who has ever worked on a few cars in their lifetime always has a bottle or two of this around.
NitroNate is offline   Reply With Quote
Old 04-16-2012, 05:43 PM   #8
I don't think we have that here.
Old 04-16-2012, 05:44 PM   #9
Or these...........
I'll persevere with the WD40 and maybe try some sewing machine oil?
Old 04-16-2012, 10:54 PM   #10
In a little over my head
Rewards Points: 706
If you can't get Kroil or PB Blaster (both good), call an auto parts store and see what's the best "penetrant" they have.
Then knock the pin out and clean with steel wool or fine sandpaper.
ratherbefishing is offline   Reply With Quote
Old 04-16-2012, 11:10 PM   #11
A Little Of Everything
Rewards Points: 1,360
+2 on PB Blaster. I may be just kidding myself, but I think it works much better than WD40.
DrHicks is online now   Reply With Quote
Old 04-17-2012, 09:41 AM   #12
Rewards Points: 22
WD40, nor sewing machine oil, are going to free up rust; one is a Water Dispersant, useful as a light coating to prevent rust on tools, etc., as well as other similar uses, and the other is a light lubricant. PB Blaster is readily available, most likely at your local hardware, auto parts store, marina, or big box, is something that you will most likely use again, and would be my first choice at solving the problem.
Old 04-17-2012, 04:48 PM   #13
Jay 78's Avatar
Agreed. WD-40 and PB Blaster are not the same product.
Under Construction
Old 04-17-2012, 05:19 PM   #14
Ravenworks's Avatar
We always soak our boom pins for the cranes in diesel fuel (kerosene) been doing it for years.
PB Blaster is good stuff too.
Ravenworks is offline   Reply With Quote
Old 04-18-2012, 01:49 AM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 818
If the hinge can be removed....do so and drop it into a bucket of vinegar. Let it soak for a few days....when you can move it by hand....give it a few moves...drop it in for a few more hours...repeat untill it looks like it is moving easy...
Rinse well with water....then soak the crap out of it with oil or WD40
door hinge into a plaster wall? dbpass Remodeling 1 05-04-2011 12:49 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
Door Hinge Questions DaveF Carpentry 6 08-21-2009 04:20 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 12:00 PM
