Best Toggle Bolt? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-01-2009, 04:44 PM   #1
Best Toggle Bolt?
Hey guys, I have a very Expensive Light to hang over a more expensive reef aquarium. Im wanting to have 2 hangers in the ceiling but might end up settling for 3 to be on the safe side. The light is 48'' long and roughly 35lbs.
Im looking for the stongest togglebolt around, maybe somthing with extra long or multiple wings.
THANKS!
kevinyates is offline   Reply With Quote
Old 08-01-2009, 09:02 PM   #2
http://www.toggler.com/products/snaptoggle/overview.php
The "industry standard safety factor" is 4 so if you have to hold up 35# you should have a fastener that pulls out at >140#.
If you use four of these fasteners each one should pull out at >35#.
The lowest factor I've heard of is 1.3, and if personal safety is involved, like for a flywheel that may explode, they use 10 to 13.
Garage swing-door install: sill bolt problem Stillwerkin Building & Construction 8 05-18-2009 09:45 PM
How to remove sheared off bolt ptcity General DIY Discussions 3 04-17-2009 10:28 PM
Problems with dead bolt in new door jkrodger Remodeling 12 01-12-2009 11:14 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Attach a bolt to drywall hdayanan Building & Construction 1 03-17-2006 08:01 AM
