Best Surface For Indoor Balcony? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-10-2013, 03:26 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Best Surface for Indoor Balcony?
Now that the outside is done....I have one more thing to handle before the rains come.
This is my balcony.....
For the most part, it is covered...but we get some pretty good winds here in S California....translation, water will get blown onto the deck....below that deck is some inside living space....translation.....drywall. I don't want it to get wet for obvious reasons.
The plans call for Mer-Ko Shur Deck...I've heard I can also do hot mop (works in my mild climate).
One of the issues is that we don't want a surface that looks like your typical balcony floor....we are thinking that we would like to either tile it...or better yet use wood...much like you would find on the deck of a ship...
I know it would be expensive...but I would love to have a surface of Teak...
Ideas...suggestions?
ddawg16 is online now   Reply With Quote
Old 09-10-2013, 04:47 PM   #2
Rewards Points: 5,974
The best of both worlds they have tile now that really looks like wood.
The Following User Says Thank You to ToolSeeker For This Useful Post:
kwikfishron (09-11-2013)
Old 09-10-2013, 10:25 PM   #3
DIY staff
Rewards Points: 7,174
Do you have a drain in there?
Old 09-11-2013, 01:19 AM   #4
JOATMON
ddawg16's Avatar
There will be.....we most likely won't get any rain for at least 2 more months...so I have 'time'....
Old 09-11-2013, 06:26 AM   #5
DIY staff
I've never waterproofed a wood floor----I wonder if Schluter, Ditra or Kerdi would be acceptable for under tile?
Under a wood floor? Not sure---Roof membrane? Removable sections of wood would be wise--so servicing the deck could be done without demolition.
Old 09-12-2013, 12:18 AM   #6
Rewards Points: 324
Its done here quite a bit, use TPO or EPDM or mod-bit roof membrane, the choice is yours, for the waterproof surface. Then these http://www.vikingroofspec.co.nz/cata...jack-pedestals to support your tile or wood surface.
Or use Deck-king membrane (from above supplier) as a finished surface. I think its a Canadian product so you probably have a supplier of these products in your area.
mgp roofing is offline   Reply With Quote
Old 09-12-2013, 08:01 AM   #7
Could you build your wood floor in small sections say like a small pallet with 1x runners. This would make them removable so you could hose and clean under them or rebuild them if damaged. Use PT for the runners.
Old 09-13-2013, 02:56 PM   #8
Rewards Points: 274
I agree with this guy.
alexjoe is offline   Reply With Quote
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 06:45 PM
Hot surface igniter and gas valve not always working during call for heat Modify_inc HVAC 12 12-10-2012 06:46 PM
12' garage work bench surface ideas? DIYguy2000 Carpentry 17 10-30-2012 11:00 AM
cleaning surface mpj111 Painting 2 04-25-2010 06:43 PM
need to slightly raise deck surface Jeremy Hillary Boob, PhD Building & Construction 3 09-01-2009 10:44 AM
