Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-06-2009, 08:16 AM   #1
Best place to buy 1.5 inch OD chome plated tubing?
Hi all,
Where's the best place to buy this stuff? McMaster? And I might eventually also need 2 inch OD chrome plated tubing. I suppose aluminum is what I want since steel is heavy and more expensive. Would aluminum wobble more when building a structure like this when pressure is applied, or is that more dependent on the OD? (mine will be taller and wider than this picture) http://redirectingat.com/?id=252X400...url3011498.jpg
Let me know, thanks!
Mod Dig is offline   Reply With Quote
Old 06-06-2009, 04:23 PM   #2
What is that thing? You really need to explain the use as it's pertinient to the choice of rod.
Home Depot sells chrome plated closet rods. Don't know the diameter, though.
Ron
Old 06-09-2009, 01:23 AM   #3
It's a drum rack. Anyone else have some info?
Thanks.
Old 06-09-2009, 07:07 AM   #4
the Musigician
DangerMouse's Avatar
pearl makes them with square aluminum, so i guess that's not out of the question, but i think i'd still go with steel. my rototoms are mounted to square tubing, but the rest of my drums/cymbals are all on steel tube.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-09-2009, 06:22 PM   #5
Thanks DangerMouse. Do you know where I can get the 1 1/2 inch OD chrome plated tubing outside of Gibraltar or DW/PDP? I know they get their stuff in bulk from China. I'm thinking if I go through another supplier I'll be able to get them cheaper than by going through the drum rack part guys.
Old 06-09-2009, 07:08 PM   #6
the Musigician
McMaster-Carr may be your best bet if you want to go with chrome or stainless steel.
but i think i'd consider black steel.... it'll blend in ok, and be LOTS cheaper..... and available locally....
DM
Old 06-09-2009, 07:34 PM   #7
Have you checked places that sells bar railing?
http://www.rockler.com/product.cfm?p...ter=bar%20rail
jerryh3 is offline   Reply With Quote
Old 06-09-2009, 09:29 PM   #8
Thanks! I'll check the differences between that and black steel.
And I don't know anything about bar railing, so I'll look into that too.
conversion of portable dishwasher to stationary one grimsbyman Plumbing 14 02-19-2013 08:54 PM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
1 1/2 inch zone valve - can't find BOUTYM HVAC 2 11-20-2008 11:03 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 12:19 PM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 09:53 PM
