Best Paint Over Metal After Rust Removed? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-11-2016, 09:36 PM   #1
Rewards Points: 372
Best paint over metal after rust removed?
I have some old rusted horse hames that I want to remove the heavy rust from and then paint them. Yes I know, crazy....
What is the best method in removing the rust (thinking of a wire drill brush or just getting them sand blasted)?
Also, what kind of paint/primer should I use? I will use rustoleum if I have too, but not a fan of it.
Yes I like old farm antiques, etc......
Alumifab is offline   Reply With Quote
Old 03-11-2016, 10:39 PM   #2
Rewards Points: 1,200
CLR for rust removal, then neutralize the acids with a scrub mix of baking soda and water, then plain water.
Any decent brand of primer afterwards, then your choice of paint.
ED
de-nagorg is online now   Reply With Quote
Old 03-12-2016, 01:22 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Re: Best paint over metal after rust removed?
Were they originally painted?
If not....clean as de-nag noted...or use vinegar with a little elbow grease....and then cover them with a light oil...and keep them oiled. Kinda like how you do cast iron pans.
If you really want to paint them....take them to a powder coat shop...they will sand blast and powder coat them
Old 03-12-2016, 02:30 AM   #4
First Home
Rewards Points: 320
A good sandblast/powder coat on those pieces would cost quite a pretty penny, way to many edges, corners and crannies. Youd pay alot in labour just for prep
I personally have great results with Por-15 over rusted pieces like this, may cost you $60 to paint them properly with the product though, they sell a metal ready product to neutralize the rust and prep it, then whatever topcoat you desire from them, be sure to read about each top coat you are considering though, some are UV sensitive
KevinEF7 is offline   Reply With Quote
Old 03-12-2016, 03:29 AM   #5
Rewards Points: 692
On this piece a wire brush, The Works house hold cleaner containing Phosphoric acid and Rustoleum paint applied. Phosphoric acid seems to be the acid of choice to reduce rust for about 24 hours.
There are parts here at the ranch that were treated 10 years ago at least with no sign of rust re-occuring.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
oh'mike (03-25-2016)
Old 03-25-2016, 08:04 AM   #6
Rewards Points: 372
After I remove the rust, what's the best way/how do I clean the surface before I prime?
I'm getting some immediate rust spots appearing after I clean the rust off.
Do I rub the metal with mineral spirits?
Old 03-25-2016, 08:10 AM   #7
Property Mgt/Maint
Rewards Points: 712
If your parts are clean and dry with very light surface rust, just rub it off with 3M Scotchbrite. No need for any chemicals.
Yodaman is online now   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Windows on Wash (03-25-2016)
Old 03-25-2016, 01:01 PM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
If you aren't going to paint in a while, just coat it with some oil and then do a final cleaning right before paint.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Lead Paint Follow-Up RoughDraft Painting 24 06-18-2013 08:31 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
